  • gsoc/gsoc.beagleboard.io
  • Krishna_13/gsoc.beagleboard.io
  • krvprashanth/gsoc.beagleboard.io
  • lorforlinux/gsoc.beagleboard.io
  • jkridner/gsoc
  • anujdeshpande/gsoc.beagleboard.io
  • ayush1325/gsoc.beagleboard.io
  • samdai/gsoc.beagleboard.io
  • abdelrahman/gsoc.beagleboard.io
  • aryan_nanda/gsoc.beagleboard.io
  • fuadzade/gsoc.beagleboard.io
  • vvaishak/gsoc.beagleboard.io
  • Roger18/gsoc.beagleboard.io
  • mclem/gsoc.beagleboard.io
  • NachtSpyder04/gsoc.beagleboard.io
  • melta101/melta101-gsoc
  • saiprasad-patil/gsoc.beagleboard.io
  • mattd/gsoc.beagleboard.io
  • SurajS0215/gsoc.beagleboard.io
  • jarm/gsoc.beagleboard.io
  • ijc/gsoc.beagleboard.io
  • himanshuk/gsoc.beagleboard.io
  • mahelaekanayake10/gsoc.beagleboard.io
  • alecdenny/gsoc.beagleboard.io
  • darshan15/gsoc.beagleboard.io
  • san.s.kar03/gsoc.beagleboard.io
  • jjateen/gsoc.beagleboard.io
  • vidhusarwal/gsoc.beagleboard.io
  • giuliomoro/gsoc.beagleboard.io
  • ketanthorat/gsoc.beagleboard.io
  • Sahil7741/gsoc.beagleboard.io
  • Whiz-Manas/mana-gsoc-beagleboard-io
  • fayezzouari/gsoc.beagleboard.io
33 results
Commits on Source (194)
with 583 additions and 215 deletions
image: beagle/sphinx-build-env:latest # The Docker image that will be used to build your app
image: registry.git.beagleboard.org/docs/sphinx-build-env:latest
pages: pages:
tags: tags:
- docker-amd64 - docker-amd64
before_script:
- source ./venv-build-env.sh
script: script:
- "./gitlab-build.sh" - "./gitlab-build.sh"
artifacts: artifacts:
paths: paths:
- public - public
\ No newline at end of file
.. _C:
https://docs.beagleboard.cc/docs/latest/intro/beagle101/c.html
.. _Assembly:
https://docs.beagleboard.cc/docs/latest/intro/beagle101/assembly.html
.. _Verilog:
https://docs.beagleboard.cc/docs/latest/intro/beagle101/verilog.html
.. _Zephyr:
https://docs.beagleboard.cc/docs/latest/intro/beagle101/zephyr.html
.. _Linux:
https://docs.beagleboard.cc/latest/intro/beagle101/linux.html
.. _device-tree:
https://docs.beagleboard.cc/docs/latest/intro/beagle101/device-tree.html
.. _FPGA:
https://docs.beagleboard.cc/docs/latest/intro/beagle101/fpga.html
.. _basic wiring:
https://docs.beagleboard.cc/docs/latest/intro/beagle101/basic-wiring.html
.. _motors:
https://docs.beagleboard.cc/docs/latest/intro/beagle101/motors.html
.. _embedded serial interfaces:
https://docs.beagleboard.cc/docs/latest/intro/beagle101/embedded-serial.html
.. _OpenBeagle CI:
https://docs.beagleboard.cc/docs/latest/intro/beagle101/openbeagle-ci.html
.. _verification:
https://docs.beagleboard.cc/docs/latest/intro/beagle101/verification.html
.. _wireless communications:
https://docs.beagleboard.cc/docs/latest/intro/beagle101/wireless-communications.html
.. _Buildroot:
https://docs.beagleboard.cc/docs/latest/intro/beagle101/buildroot.html
.. _RISC-V ISA:
https://docs.beagleboard.cc/docs/latest/intro/beagle101/riscv.html
_static/images/bash-and-boris-gosc-proposal.webp
480 KiB
<a class="btn btn-danger btn-sm btn-block text-light" role="button" href="https://bbb.io/gsocml"> {% if pagename == "ideas/index" %}
<i class="fa-brands fa-discourse"></i> Discuss on Forum <a role="button" href="https://bbb.io/gsocml">
</a> <i class="fa-brands fa-discourse"></i> More Ideas on Forum
\ No newline at end of file </a>
{% else %}
<a role="button" href="https://forum.beagleboard.org/new-topic?category=gsoc&tags=gsoc">
</a>
{% endif %}
<div class="card bg-light mt-4 text-center">
<div class="card-body">
<p class="card-text text-dark">
<a href="https://www.beagleboard.org/">BeagleBoard.org</a> is all about being open, please discuss in public on our <a href="https://bbb.io/gsocml">forum</a>!</p>
</div>
</div>
<div class="card-header bg-primary text-light">
What is the mission?
</div>
We don’t want to just make more things. We want to enable individuals to make the things that dominate their lives, rather than leaving it up to someone else. Google Summer of Code with BeagleBoard.org is a great way to learn skills highly in demand while making a difference in the world.
</p>
</div>
</div>
<div class="card-header bg-success text-light">
How to build an embedded system?
</div>
An embedded system is built using a computer dedicated to a specific purpose, like a toaster, coffee machine, dish washer, thermostat or anti-lock brakes. You can think of an embedded system as a computer designed to not look like a computer and to automate things in the physical world. The <a href="https://www.beagleboard.org/">BeagleBoard.org</a> community is loaded with experts on building open source embedded systems, join our <a href="https://bbb.io/gsocml">forum</a> to connect.
</p>
</div>
</div>
{% if pages_slug != "index" %} {% if pages_slug != "index" %}
{% for proposal_name in proposals %} {% for proposal_name in proposals %}
{% if pagename == "proposals/"+proposal_name %} {% if pagename == "proposals/"+proposal_name %}
<a class="btn btn-danger btn-sm btn-block text-light" role="button" href="{{proposal_name}}.pdf"> <a role="button" href="{{proposal_name}}.pdf">
<i class="fa-solid fa-download"></i> {{proposal_name}}.pdf <i class="fa-solid fa-download"></i> Download PDF
</a> </a>
{% endif %} {% endif %}
{% endfor %} {% endfor %}
...@@ -17,15 +17,24 @@ from sphinx.application import Sphinx ...@@ -17,15 +17,24 @@ from sphinx.application import Sphinx
sys.path.append(str(Path(".").resolve())) sys.path.append(str(Path(".").resolve()))
project = 'gsoc.beagleboard.io' project = 'gsoc.beagleboard.io'
copyright = '2024, BeagleBoard.org' copyright = '2025, BeagleBoard.org'
author = 'BeagleBoard.org' author = 'BeagleBoard.org'
# Add epilog details to rst_epilog
rst_epilog =""
rst_epilog_path = "_static/epilog/"
for (dirpath, dirnames, filenames) in os.walk(rst_epilog_path):
for filename in filenames:
with open(dirpath + filename) as f:
rst_epilog += f.read()
# -- General configuration --------------------------------------------------- # -- General configuration ---------------------------------------------------
# https://www.sphinx-doc.org/en/master/usage/configuration.html#general-configuration # https://www.sphinx-doc.org/en/master/usage/configuration.html#general-configuration
extensions = [ extensions = [
"sphinx_design", "sphinx_design",
"sphinxcontrib.youtube", "sphinxcontrib.youtube",
"sphinxcontrib.images",
"sphinx_copybutton" "sphinx_copybutton"
...@@ -57,10 +66,26 @@ html_css_files = [ ...@@ -57,10 +66,26 @@ html_css_files = [
# Pages entry without primary (left) sidebar # Pages entry without primary (left) sidebar
html_sidebars = { html_sidebars = {
"ideas/index": [], "**": ["sidebar-nav-bs", "mission"],
"ideas/index": [],
"index": []
html_theme_options = { html_theme_options = {
"external_links": [
"url": "https://summerofcode.withgoogle.com/help",
"name": "Help",
"url": "https://summerofcode.withgoogle.com/rules",
"name": "Rules",
"url": "https://summerofcode.withgoogle.com/terms",
"name": "Terms",
"header_links_before_dropdown": 4, "header_links_before_dropdown": 4,
"show_prev_next": True, "show_prev_next": True,
"icon_links": [ "icon_links": [
...@@ -106,8 +131,8 @@ html_theme_options = { ...@@ -106,8 +131,8 @@ html_theme_options = {
"use_edit_page_button": True, "use_edit_page_button": True,
"show_toc_level": 1, "show_toc_level": 1,
"navbar_align": "right", "navbar_align": "right",
"show_nav_level": 2, "show_nav_level": 1,
"announcement": "Welcome to the new site for BeagleBoard.org GSoC 2024 projects!", "announcement": "Welcome to the site for BeagleBoard.org GSoC 2025 projects!",
# "show_version_warning_banner": True, # "show_version_warning_banner": True,
"navbar_center": ["navbar-nav"], "navbar_center": ["navbar-nav"],
"navbar_start": ["navbar-logo"], "navbar_start": ["navbar-logo"],
...@@ -117,8 +142,8 @@ html_theme_options = { ...@@ -117,8 +142,8 @@ html_theme_options = {
"footer_end": ["last-updated"], "footer_end": ["last-updated"],
# "content_footer_items": ["last-updated"], # "content_footer_items": ["last-updated"],
"secondary_sidebar_items": { "secondary_sidebar_items": {
"**": ["page-toc", "edit-this-page", "sourcelink","forum","pdf"] "**": ["page-toc", "edit-this-page", "sourcelink","pdf","forum"]
proposals = [] proposals = []
...@@ -152,7 +177,7 @@ html_context = { ...@@ -152,7 +177,7 @@ html_context = {
latex_elements = { latex_elements = {
"papersize": "a4paper", "papersize": "a4paper",
"maketitle": open("_static/latex/title.tex").read(), "maketitle": open("_static/latex/title.tex").read(),
"preamble": open("_static/latex/preamble.tex").read(), "preamble": open("_static/latex/preamble.tex").read() + r"\let\cleardoublepage\clearpage",
"sphinxsetup": ",".join( "sphinxsetup": ",".join(
"verbatimwithframe=false", "verbatimwithframe=false",
...@@ -165,6 +190,7 @@ latex_elements = { ...@@ -165,6 +190,7 @@ latex_elements = {
sd_fontawesome_latex = True
latex_engine = "xelatex" latex_engine = "xelatex"
latex_logo = str("_static/images/logo-latex.pdf") latex_logo = str("_static/images/logo-latex.pdf")
latex_documents = [] latex_documents = []
...@@ -7,15 +7,29 @@ Contributor Guide ...@@ -7,15 +7,29 @@ Contributor Guide
:width: 100% :width: 100%
:align: center :align: center
.. important::
Contributors will be expected to execute a series of prerequisites to demonstrate and
expand familiarity with embedded systems development. Don't worry, the
`live chat <https://bbb.io/gsocchat>`_ channel has over 1,000 active members to
travel with you on your journey.
General requirements General requirements
.. note::
Google Summer of Code is open to individuals age 18 and older in most countries who are new or beginner
contributors to open source coding projects. Read more on the GSoC site
`Rules page <https://summerofcode.withgoogle.com/rules>`_ and the
`FAQ page <https://developers.google.com/open-source/gsoc/faq>`_.
All projects have the following basic requirements: All projects have the following basic requirements:
1. Contributors must create accounts on our `OpenBeagle <https://openbeagle.org/>`_, `Discord <https://bbb.io/gsocchat>`_ and `Beagle Forum <http://bbb.io/gsocml>`_ prior to creating their application. 1. Contributors must create accounts on our `OpenBeagle <https://openbeagle.org/>`_, `Discord <https://bbb.io/gsocchat>`_ and `Beagle Forum <http://bbb.io/gsocml>`_ prior to creating their application.
2. All newly generated materials must be released under an `open source license <http://www.opensource.org/licenses>`_. Individual contributors shall retain copyright on their works. 2. All newly generated materials must be released under an `open source license <http://www.opensource.org/licenses>`_. Individual contributors shall retain copyright on their works.
3. Contributors will demonstrate their ability to cross-compile and utilize version control software by creating a “Hello World” application and generating a pull request to `jadonk/gsoc-application <https://github.com/jadonk/gsoc-application/tree/master/ExampleEntryJasonKridner>`_. For assistance, please visit our `Discord <https://bbb.io/gsocchat>`_ or utilize the `Beagle Forum <http://bbb.io/gsocml>`_. The “Hello World” application must print your name and the date out in an ARM Linux environment. Freely available emulators may be used to test your application or you can ask anyone on the chat or mailing list to help you test. 3. Contributors will demonstrate their ability to cross-compile and utilize version control software by creating a “Hello World” application and generating a pull request to `jadonk/gsoc-application <https://github.com/jadonk/gsoc-application/tree/master/ExampleEntryJasonKridner>`_. For assistance, please visit our `Discord <https://bbb.io/gsocchat>`_ or utilize the `Beagle Forum <http://bbb.io/gsocml>`_. The “Hello World” application must print your name and the date out in an ARM Linux environment. Freely available emulators may be used to test your application or you can ask anyone on the chat or mailing list to help you test.
4. All projects will produce reusable software components and will not be “whatI-built-over-my-summer-vacation” projects. Including a hardware component is welcome, but the project deliverable will be software that may be utilized by a wide audience of the `BeagleBoard.org <https://www.beagleboard.org/>`_ community. 4. All projects will produce reusable software components and will not be “what-I-built-over-my-summer-vacation” projects. Including a hardware component is welcome, but the project deliverable will be software that may be utilized by a wide audience of the `BeagleBoard.org <https://www.beagleboard.org/>`_ community.
5. Contributors will demonstrate their ability to collaborate by creating a project proposal on this site using our :ref:`proposal template <gsoc-proposal-template>` and utilizing our `Discord <https://bbb.io/gsocchat>`_ to collect quotes regarding the usefulness of their proposal to the `BeagleBoard.org <https://www.beagleboard.org/>`_ community. **Use of Google Docs for proposal development is discouraged due to insufficient revision control and extensive use of computing resources having numerous documents open simultaneously**. 5. Contributors will demonstrate their ability to collaborate by creating a project proposal on this site using our :ref:`proposal template <gsoc-proposal-template>` and utilizing our `Discord <https://bbb.io/gsocchat>`_ to collect quotes regarding the usefulness of their proposal to the `BeagleBoard.org <https://www.beagleboard.org/>`_ community. **Use of Google Docs for proposal development is discouraged due to insufficient revision control and extensive use of computing resources having numerous documents open simultaneously**.
6. Source code generated during the project must be released on `OpenBeagle <https://openbeagle.org/>`_ (and we’ll setup a mirror on `Github.com <http://github.com/>`_). 6. Source code generated during the project must be released on `OpenBeagle <https://openbeagle.org/>`_ (and we’ll setup a mirror on `Github.com <http://github.com/>`_).
7. Contributors will provide two recorded audio/video presentations uploaded to Youtube or Vimeo (screencasts are appropriate), one near the beginning of the project summarizing their project goals and another in the wrap-up phase to summarize their accomplishments. Examples can be found in :ref:`Past_Projects`. There is no requirement to show your faces or use English. 7. Contributors will provide two recorded audio/video presentations uploaded to Youtube or Vimeo (screencasts are appropriate), one near the beginning of the project summarizing their project goals and another in the wrap-up phase to summarize their accomplishments. Examples can be found in :ref:`Past_Projects`. There is no requirement to show your faces or use English.
...@@ -3,8 +3,23 @@ ...@@ -3,8 +3,23 @@
Guides Guides
.. youtube:: 7jD2tChhrWM
:width: 100%
:align: center
.. admonition:: What is Google Summer of Code?
:class: admonition-code
Spend your summer break writing code and learning about open source development while earning money!
Accepted contributors work with a mentor and become a part of the open source community. Many become lifetime
open source developers! The 2025 contributor application window will be open from
`March 24 2025 <https://opensource.googleblog.com/2025/01/google-summer-of-code-2025-is-here.html>`_ to
`April April 8 2025 <https://opensource.googleblog.com/2025/01/google-summer-of-code-2025-is-here.html>`_!
But don't wait for then to engage! Come to our `Discord <https://bbb.io/gsocchat>`_ and
`Forum <https://bbb.io/gsocml>`_ to share ideas today.
This section includes guides for :ref:`contributors <gsoc-contributor-guide>` & :ref:`mentors <gsoc-mentor-guide>` who want to participate This section includes guides for :ref:`contributors <gsoc-contributor-guide>` & :ref:`mentors <gsoc-mentor-guide>` who want to participate
in GSoC 2024 with `BeagleBoard.org <www.beagleboard.org>`_. It's highly recommended to check `GSoC Frequently Asked Questions in GSoC 2025 with `BeagleBoard.org <www.beagleboard.org>`_. It's highly recommended to check `GSoC Frequently Asked Questions
<https://developers.google.com/open-source/gsoc/faq>`_. For anyone who just want to contribute to this site we also have <https://developers.google.com/open-source/gsoc/faq>`_. For anyone who just want to contribute to this site we also have
a step by step :ref:`contribution guide <gsoc-site-editing-guide>`. a step by step :ref:`contribution guide <gsoc-site-editing-guide>`.
...@@ -14,7 +14,7 @@ Mentor Guide ...@@ -14,7 +14,7 @@ Mentor Guide
become familiar with the code base and testing practices, to finally releasing their code on become familiar with the code base and testing practices, to finally releasing their code on
`OpenBeagle <https://openbeagle.org/>`_ for the world to use! `OpenBeagle <https://openbeagle.org/>`_ for the world to use!
You will also need be invited by an administrator to register on the GSoC site and request You will also need to be invited by an administrator to register on the GSoC site and request
to be a mentor for `BeagleBoard.org <https://www.beagleboard.org/>`_. to be a mentor for `BeagleBoard.org <https://www.beagleboard.org/>`_.
Who Are Mentors? Who Are Mentors?
...@@ -25,7 +25,7 @@ with a GSoC contributor. Mentors provide guidance such as pointers to useful doc ...@@ -25,7 +25,7 @@ with a GSoC contributor. Mentors provide guidance such as pointers to useful doc
In addition to providing GSoC contributors with feedback and pointers, a mentor acts as an ambassador to help In addition to providing GSoC contributors with feedback and pointers, a mentor acts as an ambassador to help
GSoC contributors integrate into their project’s community. `BeagleBoard.org <https://www.beagleboard.org/>`_ GSoC contributors integrate into their project’s community. `BeagleBoard.org <https://www.beagleboard.org/>`_
always assigns more than one mentor to each of GSoC contributor. Many members of `BeagleBoard.org <https://www. always assigns more than one mentor to each of GSoC contributor. Many members of `BeagleBoard.org <https://www.
beagleboard.org/>`_ community also provide guidance to GSoC contributors without mentoring in an “official” beagleboard.org/>`_ community also provides guidance to GSoC contributors without mentoring in an “official”
capacity, as much as they would answer anyone’s questions on our `Discord <https://bbb.io/gsocchat>`_ and our capacity, as much as they would answer anyone’s questions on our `Discord <https://bbb.io/gsocchat>`_ and our
`Forum <https://bbb.io/gsocml>`_. `Forum <https://bbb.io/gsocml>`_.
...@@ -34,7 +34,7 @@ Idea Submission Process ...@@ -34,7 +34,7 @@ Idea Submission Process
Mentors should: Mentors should:
1. Submit projects ideas to our `Forum <https://bbb.io/gsocml>`_ and then 1. Submit project ideas to our `Forum <https://bbb.io/gsocml>`_ and then
2. Contribute an update to our :ref:`gsoc-project-ideas` page using our :ref:`gsoc-site-editing-guide` to promote their idea to contributors. 2. Contribute an update to our :ref:`gsoc-project-ideas` page using our :ref:`gsoc-site-editing-guide` to promote their idea to contributors.
Only ideas deemed by administrators as being sufficiently supported by qualified mentors will be merged. Only ideas deemed by administrators as being sufficiently supported by qualified mentors will be merged.
...@@ -44,11 +44,11 @@ Only ideas deemed by administrators as being sufficiently supported by qualified ...@@ -44,11 +44,11 @@ Only ideas deemed by administrators as being sufficiently supported by qualified
BeagleBoard.org mentored GSoC projects are supposed to be for software projects that service the Beagle and general open source BeagleBoard.org mentored GSoC projects are supposed to be for software projects that service the Beagle and general open source
embedded systems community, not theses, how-to guides or what I did over my summer vacation ideas. embedded systems community, not theses, how-to guides or what I did over my summer vacation ideas.
Prospective mentors, sudents will use our `Discord <https://bbb.io/gsocchat>`_ and `Forum <https://bbb.io/gsocml>`_ Prospective mentors, students will use our `Discord <https://bbb.io/gsocchat>`_ and `Forum <https://bbb.io/gsocml>`_
to make contact with you, so be sure to provide up-to-date information. Please feel free to add yourself on mentors page and we will monitor to make contact with you, so be sure to provide up-to-date information. Please feel free to add yourself on mentors page and we will monitor
and police that list. Acceptance as an official mentor with the ability to rate proposals and grade contributors will come via the Google system. and police that list. Acceptance as an official mentor with the ability to rate proposals and grade contributors will come via the Google system.
We will only approve official mentors who have a proven track record with Beagle, but welcome all community members to provide guidance to both We will only approve official mentors who have a proven track record with Beagle, but welcome all community members to provide guidance to both
mentors and contributors to best service the community as a whole. Don’t be shy and don’t be offended when we edit. We are thrilled to have you on-board! mentors and contributors to best serve the community as a whole. Don’t be shy, and don’t be offended when we edit. We are thrilled to have you on board!
...@@ -21,7 +21,7 @@ How to write an *unsuccessful* proposal ...@@ -21,7 +21,7 @@ How to write an *unsuccessful* proposal
Unsuccessful proposals often: Unsuccessful proposals often:
1. Try to pass off previous school projects as something to do for GSoC. The work has already done, and the project often has very little to do with `BeagleBoard.org hardware <https://www.beagleboard.org/boards>`_, 1. Try to pass off previous school projects as something to do for GSoC. The work is already done, and the project often has very little to do with `BeagleBoard.org hardware <https://www.beagleboard.org/boards>`_,
2. Show up shortly before the submission deadline with only a half page of “proposal”, being little more than a name, contact information, and a statement of “I will work hard”, 2. Show up shortly before the submission deadline with only a half page of “proposal”, being little more than a name, contact information, and a statement of “I will work hard”,
3. Are generic and sent to every other GSoC org with very few details on deliverables or schedule, or 3. Are generic and sent to every other GSoC org with very few details on deliverables or schedule, or
4. Introduce an idea that was never talked about to the `BeagleBoard.org <https://www.beagleboard.org/>`_ mentors in our `Forum <https://bbb.io/gsocml>`_ and submitted without ever engaging the Beagle community. 4. Introduce an idea that was never talked about to the `BeagleBoard.org <https://www.beagleboard.org/>`_ mentors in our `Forum <https://bbb.io/gsocml>`_ and submitted without ever engaging the Beagle community.
...@@ -49,7 +49,7 @@ To make the project proposal writing process easier for all the GSoC contributor ...@@ -49,7 +49,7 @@ To make the project proposal writing process easier for all the GSoC contributor
.. tip:: .. tip::
Start with :ref:`gsoc-site-editing-guide` to simplify the proposal writing process using OpenBeagle CI. It's always recommended to create a fork Start with :ref:`gsoc-site-editing-guide` to simplify the proposal writing process using OpenBeagle CI. It's always recommended to create a fork
of `gsoc.beagleboard.io repo on OpenBeagle <https://openbeagle.org/gsoc/gsoc.beagleboard.io>`_ and clone on your local machine. Instructions for of `gsoc.beagleboard.io repo on OpenBeagle <https://openbeagle.org/gsoc/gsoc.beagleboard.io>`_ and clone on your local machine. Instructions for
setting up Sphinx on local machine are also provided on :ref:`gsoc-site-editing-guide`. For any query you, can reach out on setting up Sphinx on local machine are also provided on :ref:`gsoc-site-editing-guide`. For any query, you can reach out on
our `Discord <https://bbb.io/gsocchat>`_ or `Forum <https://bbb.io/gsocml>`_. our `Discord <https://bbb.io/gsocchat>`_ or `Forum <https://bbb.io/gsocml>`_.
You can either open your cloned `gsoc.beagleboard.io repo <https://openbeagle.org/gsoc/gsoc.beagleboard.io>`_ using Visual Studio Code on your local machine or use OpenBeagle Web IDE. Now, follow steps below to write your proposal, You can either open your cloned `gsoc.beagleboard.io repo <https://openbeagle.org/gsoc/gsoc.beagleboard.io>`_ using Visual Studio Code on your local machine or use OpenBeagle Web IDE. Now, follow steps below to write your proposal,
...@@ -65,9 +65,8 @@ You can either open your cloned `gsoc.beagleboard.io repo <https://openbeagle.or ...@@ -65,9 +65,8 @@ You can either open your cloned `gsoc.beagleboard.io repo <https://openbeagle.or
.. raw:: html .. raw:: html
<br> <a role="button" href="">
<a class="btn btn-danger btn-sm btn-block text-light" role="button" href="/proposals/template.pdf"> <i class="fa-solid fa-download"></i> Download PDF
<i class="fa-solid fa-download"></i> template.pdf
</a> </a>
...@@ -68,7 +68,7 @@ After selecting the file you have to click on ``edit button`` and then choose ei ...@@ -68,7 +68,7 @@ After selecting the file you have to click on ``edit button`` and then choose ei
.. note:: .. note::
Choosing ``Web IDE`` will load a `Visual Studio Code Server <https://code.visualstudio.com/docs/remote/vscode-server>`_ Choosing ``Web IDE`` will load a `Visual Studio Code Server <https://code.visualstudio.com/docs/remote/vscode-server>`_
instance which is a feature rich source code editor. Depending on the internent connection your machine will take some to instance which is a feature rich source code editor. Depending on the internent connection, your machine will take some time to
load the editor and it can be a bit heavy for some machines to handle. Once fully loaded it should run smoothly but, if that is load the editor and it can be a bit heavy for some machines to handle. Once fully loaded it should run smoothly but, if that is
not the case then please consider using single file editor option. Considering majority of the users will be using ``Web IDE`` option, not the case then please consider using single file editor option. Considering majority of the users will be using ``Web IDE`` option,
we are using the ``Web IDE`` for the rest of this guide. we are using the ``Web IDE`` for the rest of this guide.
...@@ -107,11 +107,11 @@ Now you have to select a file and start editing. Below image shows some, ...@@ -107,11 +107,11 @@ Now you have to select a file and start editing. Below image shows some,
.. tip:: Just like you do on your normal Visual Studio Code desktop application, to commit your changes you can either .. tip:: Just like you do on your normal Visual Studio Code desktop application, to commit your changes you can either
click on Source control ( :fa:`code-branch;pst-color-secondary` ) button or press ``CTRL + SHIFT + G`` to see all the edited fils. click on Source control ( :fa:`code-branch;pst-color-secondary` ) button or press ``CTRL + SHIFT + G`` to see all the edited files.
After swithing to source control you have to, After switching to source control you have to,
1. Add a commit message in the input feild. 1. Add a commit message in the input field.
2. Click on ``Commit to main`` button or click on drop down button to choose ``Commit to new branch``. 2. Click on ``Commit to main`` button or click on drop down button to choose ``Commit to new branch``.
.. image:: media/commit-changes.png .. image:: media/commit-changes.png
...@@ -132,17 +132,17 @@ ee/user/project/protected_branches.html>`_ by default. ...@@ -132,17 +132,17 @@ ee/user/project/protected_branches.html>`_ by default.
.. image:: media/commit-branch.png .. image:: media/commit-branch.png
When all done right, the lower right side of the ``Web IDE`` you'll a prompt showing ``Success! Your changes have been committed`` message with When all done right, at the lower right side of the ``Web IDE`` you'll see a prompt showing ``Success! Your changes have been committed`` message with
two button, two buttons,
1. ``Got to Project`` 1. ``Go to Project``
2. ``Continue working`` 2. ``Continue working``
.. image:: media/commit-success.png .. image:: media/commit-success.png
If you click on ``Go to Project`` button, you'll see the commit successfully applied as shown in the red box in the image below and the If you click on ``Go to Project`` button, you'll see the commit successfully applied as shown in the red box in the image below and the
green tick shows on the right side indicates that the CI build was also successful. green tick shown on the right side indicates that the CI build was also successful.
.. image:: media/commit.png .. image:: media/commit.png
...@@ -156,15 +156,15 @@ Create a pull request ...@@ -156,15 +156,15 @@ Create a pull request
After making your changes and commiting them to your forked repo, you are set to create a new `pull request / merge request After making your changes and commiting them to your forked repo, you are set to create a new `pull request / merge request
<https://en.wikipedia.org/wiki/Distributed_version_control#Pull_requests>`_ so that those changes can be merged to upstream <https://en.wikipedia.org/wiki/Distributed_version_control#Pull_requests>`_ so that those changes can be merged to upstream
repo. To start your new PR click on the dedicated button to create a new merge request and fill out all the details. The image repo. To start your new PR, click on the dedicated button to create a new merge request and fill out all the details. The image
below shows all the feilds you have to update, below shows all the fields you have to update,
1. Provided a good title that reflects your work. 1. Provide a good title that reflects your work.
2. Add a detailed description of the work you have done. Add pictures whenever seems useful. 2. Add a detailed description of the work you have done. Add pictures whenever seems useful.
3. (Optional) you can assign it to yourself if you'll be working on further updates or assign it to someone else who might want to work on the comments we may provide on your work. 3. (Optional) you can assign it to yourself if you'll be working on further updates or assign it to someone else who might want to work on the comments we may provide on your work.
4. Add ``lorforlinux`` or ``jkridner`` as reviewer for PRs with site content update or add your mentor as reviewer if it's related to project work / proposal. 4. Add ``lorforlinux`` or ``jkridner`` as reviewer for PRs with site content update or add your mentor as reviewer if it's related to project work / proposal.
5. If you want your commits to be shows as a single commit then you can choose the ``sqash commits ...`` check box. 5. If you want your commits to be shown as a single commit, then you can choose the ``sqash commits ...`` check box.
6. Check if all your commits are shown in the bottom of the screen and if everything looks okay then click on ``Create merge request`` button. 6. Check if all your commits are shown in the bottom of the screen and if everything looks okay, then click on ``Create merge request`` button.
.. tip:: If you are still working on some updates, you may also choose ``Mark as draft`` checkbox (below title) .. tip:: If you are still working on some updates, you may also choose ``Mark as draft`` checkbox (below title)
which indicates that you are seeking feedback before making your commits suitable to merge. which indicates that you are seeking feedback before making your commits suitable to merge.
:html_theme.sidebar_primary.remove: true :html_theme.sidebar_primary.remove: true
:sd_hide_title: true
.. _gsoc-project-ideas: .. _gsoc-project-ideas:
Ideas Ideas
.. sidebar:: Welcome .. image:: ../_static/images/ideas-below.webp
:align: center
Welcome to the project ideas page for `GSoC 2024 <https://developers.google.com/open-source/gsoc/timeline>`_. The .. admonition:: How to participate?
BeagleBoard.org community is loaded with experts on building open source embedded systems. An embedded
.. sidebar:: Did you know? Contributors are expected to go through the list of ideas dropdown below and join the discussion by clicking on the
BeagleBoard.org has been accepted to be a mentoring organization in the Google Summer of Code (GSoC) for twelve previous years!
.. sidebar:: How to participate?
Contributors are expected to go through the list of ideas below and join the discussion by clicking on the
``Discuss on forum`` button. All ideas have colorful badges for ``Complexity`` and ``Discuss on forum`` button. All ideas have colorful badges for ``Complexity`` and
``Size`` for making the selection process easier for contributors. Anyone is welcome to ``Size`` for making the selection process easier for contributors. Anyone is welcome to
introduce new ideas via the `forum gsoc-ideas tag <https://forum.beagleboard.org/tag/gsoc-ideas>`_. introduce new ideas via the `forum gsoc-ideas tag <https://forum.beagleboard.org/tag/gsoc-ideas>`_.
Only ideas with sufficiently experienced mentor backing as deemed by the administrators will Only ideas with sufficiently experienced mentor backing as deemed by the administrators will
be added here. be added here.
.. table:: +------------------------------------+-------------------------------+
| Complexity | Size |
| :bdg-danger:`High complexity` | :bdg-danger-line:`350 hours` |
| :bdg-success:`Medium complexity` | :bdg-success-line:`175 hours` |
| :bdg-info:`Low complexity` | :bdg-info-line:`90 hours` |
.. tip::
Below are the latest project ideas, you can also check our our :ref:`gsoc-old-ideas` and :ref:`Past_Projects` for inspiration.
.. card:: Upstream Greybus module for Zephyr
:fas:`timeline;pst-color-secondary` RTOS/microkernel imporvements :bdg-success:`Medium complexity` :bdg-danger-line:`350 hours`
Greybus support for Zephyr is currently an out of tree module. This makes it hard to maintain, and makes it almost impossible for other people to test and contribute.
The goal of the project is to get greybus and BeagleConnect Technology ecosystem to a point that is easier to test and maintain. It can be considered a continuation of Replace GBridge Project from 2023
| **Goal:** Add testing, cleanup mikroBUS support, submit upstream and respond to feedback.
| **Hardware Skills:** basic wiring
| **Software Skills:** device-tree, C, ZephyrRTOS, Linux, TCP.
| **Possible Mentors:** `Ayush Singh <https://forum.beagleboard.org/u/ayush1325>`_, `Jason Kridner <https://forum.beagleboard.org/u/jkridner>`_
.. button-link:: https://forum.beagleboard.org/t/upstream-greybus-module-for-zephyr/41170
:color: danger
:expand:
:fab:`discourse;pst-color-light` Discuss on forum
.. card:: A Conversational AI Assistant for BeagleBoard using RAG and Fine-tuning
:fas:`brain;pst-color-secondary` Deep Learning :bdg-success:`Medium complexity` :bdg-success-line:`175 hours`
BeagleBoard currently lacks an AI-powered assistant to help users troubleshoot errors. This project aims to address that need while also streamlining the onboarding process for new contributors, enabling them to get started more quickly.
| **Goal:** Develop a domain-specific chatbot for BeagleBoard using a combination of RAG and fine-tuning of an open-source LLM (like Llama 3, Mixtral, or Gemma). This chatbot will assist users with troubleshooting, provide information about BeagleBoard products, and streamline the onboarding process for new contributors.
| **Hardware Skills:** Ability to test applications on BeagleBone AI-64/BeagleY-AI and optimize for performance using quantization techniques.
| **Software Skills:** Python, RAG, Scraping techniques, Fine tuning LLMs, Gradio, Hugging Face Inference Endpoints, NLTK/spaCy, Git
| **Possible Mentors:** `Aryan Nanda <https://forum.beagleboard.org/u/aryan_nanda/>`_
.. button-link:: https://forum.beagleboard.org/t/beaglemind/40806
:color: danger
:expand:
.. card:: Update beagle-tester for mainline testing
:fab:`linux;pst-color-primary` Linux kernel improvements :bdg-success:`Medium complexity` :bdg-danger-line:`350 hours`
Utilize the ``beagle-tester`` application and ``Buildroot`` along with device-tree and udev symlink concepts within
the OpenBeagle continuous integration server context to create a regression test suite for the Linux kernel
and device-tree overlays on various Beagle computers.
+------------------------------------+-------------------------------+ | **Goal:** Execution on Beagle test farm with over 30 mikroBUS boards testing all mikroBUS enabled cape interfaces (PWM, ADC, UART, I2C, SPI, GPIO and interrupt) performing weekly mainline Linux regression verification
| Complexity | Size | | **Hardware Skills:** `basic wiring`_, `embedded serial interfaces`_
+====================================+===============================+ | **Software Skills:** `device-tree`_, `Linux`_, `C`_, `OpenBeagle CI`_, `Buildroot`_
| :bdg-danger:`High complexity` | :bdg-danger-line:`350 hours` | | **Possible Mentors:** `Deepak Khatri <https://forum.beagleboard.org/u/lorforlinux>`_, `Anuj Deshpande <https://forum.beagleboard.org/u/Anuj_Deshpande>`_, `Dhruva Gole <https://forum.beagleboard.org/u/dhruvag2000>`_
.. sidebar:: Looking for more? ++++
Please visit `our forum <https://forum.beagleboard.org/t/gsoc-ideas>`_ to see newer ideas being discussed! .. button-link:: https://forum.beagleboard.org/t/update-beagle-tester-for-cape-mikrobus-new-board-and-upstream-testing/37279
:color: danger
:expand:
You can also check our our :ref:`gsoc-old-ideas` and :ref:`Past_Projects` for inspiration. :fab:`discourse;pst-color-light` Discuss on forum
.. sidebar:: What is the mission? .. card:: Upstream wpanusb and bcfserial
We don't want to just make more things. We want to enable individuals to make the things that dominate their lives, :fab:`linux;pst-color-primary` Linux kernel improvements :bdg-success:`Medium complexity` :bdg-success-line:`175 hours`
rather than leaving it up to someone else. Google Summer of a Code with BeagleBoard.org is a great way to learn
skills highly in demand while making a difference in the world. ^^^^
.. grid:: 1 1 1 1 These are the drivers that are used to enable Linux to use a BeagleConnect Freedom as a SubGHz IEEE802.15.4 radio (gateway).
:margin: 4 4 0 0 They need to be part of upstream Linux to simplify on-going support. There are several gaps that are known before they are
:gutter: 1 acceptable upstream.
.. grid-item:: | **Goal:** Add functional gaps, submit upstream patches for these drivers and respond to feedback
| **Hardware Skills:** `wireless communications`_
| **Software Skills:** `C`_, `Linux`_
.. image:: ../_static/images/ideas-below.webp ++++
:align: center
.. grid-item-card:: .. button-link:: https://forum.beagleboard.org/t/upstream-wpanusb-and-bcfserial/37186
:color: danger
:expand:
:fas:`exclamation;pst-color-danger` Important: **No direct messages** :fab:`discourse;pst-color-light` Discuss on forum
BeagleBoard.org is all about being open. Please keep discussion in public .. card:: ``librobotcontrol`` support for newer boards
on `our forum <https://bbb.io/gsocml>`_.
.. grid-item-card:: Low-latency I/O RISC-V CPU core in FPGA fabric :fas:`wand-sparkles;pst-color-danger` Automation and industrial I/O :bdg-success:`Medium complexity` :bdg-success-line:`175 hours`
| :fas:`microchip;pst-color-primary` FPGA gateware improvements ^^^^
BeagleV-Fire features RISC-V 64-bit CPU cores and FPGA fabric. In that FPGA fabric, we'd like to Preliminary librobotcontrol support for BeagleBone AI, BeagleBone AI-64 and BeagleV-Fire has been drafted, but it
implement a RISC-V 32-bit CPU core with operations optimized for low-latency GPIO. This is similar needs to be cleaned up. We can also work on support for Raspberry Pi if UCSD releases their Hat for it.
to the programmable real-time unit (PRU) RISC cores popularized on BeagleBone Black.
| **Goal:** RISC-V-based CPU on BeagleV-Fire FPGA fabric with GPIO | **Goal:** Update librobotcontrol for Robotics Cape on BeagleBone AI, BeagleBone AI-64 and BeagleV-Fire
| **Hardware Skills:** Verilog, Verification, FPGA | **Hardware Skills:** `basic wiring`_, `motors`_
| **Software Skills:** RISC-V ISA, assembly, `Linux`_ | **Software Skills:** `C`_, `Linux`_
| **Possible Mentors:** `Cyril Jean <https://forum.beagleboard.org/u/vauban>`_, `Jason Kridner <https://forum.beagleboard.org/u/jkridner>`_ | **Possible Mentors:** `Deepak Khatri <https://forum.beagleboard.org/u/lorforlinux>`_, `Jason Kridner <https://forum.beagleboard.org/u/jkridner>`_
+++ .. button-link:: https://forum.beagleboard.org/t/librobotcontrol-support-for-newer-boards/37187
.. button-link:: https://forum.beagleboard.org/t/low-latency-risc-v-i-o-cpu-core/37156 :color: danger
:color: danger :expand:
:expand:
:fab:`discourse;pst-color-light` Discuss on forum :fab:`discourse;pst-color-light` Discuss on forum
.. card:: Upstream Zephyr Support on BBAI-64 R5
.. grid-item-card:: Update beagle-tester for mainline testing :fas:`timeline;pst-color-secondary` RTOS/microkernel imporvements :bdg-success:`Medium complexity` :bdg-danger-line:`350 hours`
| :fab:`linux;pst-color-primary` Linux kernel improvements Incorporating Zephyr RTOS support onto the Cortex-R5 cores of the TDA4VM SoC along with Linux operation on the A72 core. The objective is to harness the combined capabilities of both systems
| :bdg-success:`Medium complexity` :bdg-danger-line:`350 hours` to support BeagleBone AI-64.
Utilize the ``beagle-tester`` application and ``Buildroot`` along with device-tree and udev symlink concepts within | **Goal:** submit upstream patches to support BeagleBone AI-64 and respond to feedback
the OpenBeagle continuous integration server context to create a regression test suite for the Linux kernel | **Hardware Skills:** Familiarity with ARM Cortex R5
and device-tree overlays on various Beagle computers. | **Software Skills:** `C`_, `RTOS <https://docs.zephyrproject.org/latest/develop/getting_started/index.html>`_
| **Possible Mentors:** `Dhruva Gole <https://forum.beagleboard.org/u/dhruvag2000>`_, `Nishanth Menon <https://forum.beagleboard.org/u/nishanth_menon>`_
| **Upstream Repository:** `The primary repository for Zephyr Project <https://github.com/zephyrproject-rtos/zephyr>`_
| **Goal:** Execution on Beagle test farm with over 30 mikroBUS boards testing all mikroBUS enabled cape interfaces (PWM, ADC, UART, I2C, SPI, GPIO and interrupt) performing weekly mainline Linux regression verification ++++
| **Hardware Skills:** basic wiring, familiarity with embedded serial interfaces
| **Software Skills:** device-tree, `Linux`_, `C`_, continuous integration with GitLab, Buildroot
+++ .. button-link:: https://forum.beagleboard.org/t/upstream-zephyr-support-on-bbai-64-r5/37294/1
.. button-link:: https://forum.beagleboard.org/t/update-beagle-tester-for-cape-mikrobus-new-board-and-upstream-testing/37279 :color: danger
:expand:
.. grid-item-card:: Upstream wpanusb and bcfserial
| :fab:`linux;pst-color-primary` Linux kernel improvements .. card:: ALSA linux driver for Bela cape
These are the drivers that are used to enable Linux to use a BeagleConnect Freedom as a SubGHz IEEE802.15.4 radio (gateway). :fas:`wand-sparkles;pst-color-danger` Linux kernel audio :bdg-success:`Medium complexity` :bdg-success-line:`175 hours or longer`
| **Goal:** Add functional gaps, submit upstream patches for these drivers and respond to feedback ^^^^
| **Hardware Skills:** Familiarity with wireless communication
+++ The Bela cape rev C comes with a ES9080Q 8-channel DAC and a TLV320AIC3104 stereo codec. The former has no support on Linux, while the latter is well supported. This project involves:
.. button-link:: https://forum.beagleboard.org/t/upstream-wpanusb-and-bcfserial/37186 - writing a driver for the ES9080Q, which interacts with existing McASP and DMA drivers
:color: danger - have the ES9080Q and TLV320AIC3104 show up as a single ALSA device with 2
:expand: inputs and 10 outputs. Explore whether this can happen via a simple wrapper
in the device tree or requires a dedicated driver.
:fab:`discourse;pst-color-light` Discuss on forum | **Goal:** Upstream support of ES9080Q; simultaneous access to ES9080Q and TLV320AIC3104 via ALSA
| **Hardware Skills:** basic wiring, logic analyzer
| **Software Skills:** `C`_ or `Rust`_, `Linux`_
| **Possible Mentors:** `Giulio Moro <https://forum.beagleboard.org/u/giuliomoro>`_
| **Upstream Repository:** `Design files for the Bela cape Rev C <https://github.com/BelaPlatform/bela-hardware/tree/master/cape/bela_cape_rev_C3>`_
| **References:** `The Bela repo shows how to access these devices with a custom driver and DMA running on the PRU. <https://github.com/BelaPlatform/Bela/blob/master/pru/pru_rtaudio_irq.p>`_
.. grid-item-card:: ``librobotcontrol`` support for newer boards ++++
| :fas:`wand-sparkles;pst-color-danger` Automation and industrial I/O .. button-link:: https://forum.beagleboard.org/t/alsa-drivers-for-es9080q-and-tlv320aic3104/41532
| :bdg-success:`Medium complexity` :bdg-success-line:`175 hours` :color: danger
^^^ :expand:
Preliminary librobotcontrol support for BeagleBone AI, BeagleBone AI-64 and BeagleV-Fire has been drafted, but it :fab:`discourse;pst-color-light` Discuss on forum
| **Hardware Skills:** Basic wiring, some DC motor familiarity
:color: danger
:expand:
.. button-link:: https://forum.beagleboard.org/tag/gsoc-ideas .. button-link:: https://forum.beagleboard.org/tag/gsoc-ideas
:color: light :color: danger
:expand: :expand:
:outline:
:fab:`discourse;pst-color-light` Visit our forum for more ideas :fab:`discourse;pst-color-light` Visit our forum to see newer ideas being discussed!
.. _Linux: .. toctree::
https://docs.beagleboard.org/latest/intro/beagle101/linux.html :hidden:
.. _C: old/index
https://jkridner.beagleboard.io/docs/latest/intro/beagle101/learning-c.html
...@@ -17,13 +17,15 @@ into professional automation tasks, is strongly desired. ...@@ -17,13 +17,15 @@ into professional automation tasks, is strongly desired.
- **Goal:** Complete implementation of librobotcontrol on BeagleBone AI/AI-64. - **Goal:** Complete implementation of librobotcontrol on BeagleBone AI/AI-64.
- **Hardware Skills:** Basic wiring - **Hardware Skills:** `basic wiring`_, `motors`_
- **Software Skills:** C, Linux - **Software Skills:** `C`_, `Linux`_
- **Possible Mentors:** jkridner, lorforlinux - **Possible Mentors:** `Jason Kridner <https://forum.beagleboard.org/u/jkridner>`_, `Deepak Khatri <https://forum.beagleboard.org/u/lorforlinux>`_
- **Expected Size of Project:** 350 hrs - **Expected Size of Project:** 175 hrs
- **Rating:** Medium - **Rating:** Medium
- **Upstream Repository:** https://github.com/jadonk/librobotcontrol/tree/bbai - **Upstream Repository:** `BeagleBoard.org / librobotcontrol · GitLab <https://openbeagle.org/beagleboard/librobotcontrol>`_
- **References:** - **References:**
- `Robotics Control Library — BeagleBoard Documentation <https://docs.beagle.cc/projects/librobotcontrol/docs/index.html>`_
- `Robot Control Library: Main Page <https://old.beagleboard.org/static/librobotcontrol/>`_
- http://www.strawsondesign.com/docs/librobotcontrol/index.html - http://www.strawsondesign.com/docs/librobotcontrol/index.html
...@@ -14,6 +14,48 @@ For some background, be sure to check out `simplify embedded edge AI development ...@@ -14,6 +14,48 @@ For some background, be sure to check out `simplify embedded edge AI development
<https://e2e.ti.com/blogs_/b/process/posts/simplify-embedded-edge-ai-development>`_ <https://e2e.ti.com/blogs_/b/process/posts/simplify-embedded-edge-ai-development>`_
post from TI. post from TI.
.. card:: Enhanced Media Experience with AI-Powered Commercial Detection and Replacement
:fas:`brain;pst-color-secondary` Deep Learning :bdg-success:`Medium complexity` :bdg-danger-line:`350 hours`
Leveraging the capabilities of BeagleBoard’s powerful processing units, the project will focus on creating a real-time, efficient solution that enhances media consumption experiences by seamlessly integrating custom audio streams during commercial breaks.
| **Goal:** Build a deep learning model, training data set, training scripts, and a runtime for detection and modification of the video stream.
| **Hardware Skills:** Ability to capture and display video streams using `BeagleBone AI-64 <https://www.beagleboard.org/boards/beaglebone-ai-64>`_
| **Software Skills:** `Python <https://www.python.org/>`_, `TensorFlow <https://www.tensorflow.org/>`_, `TFlite <https://www.tensorflow.org/lite>`_, `Keras <https://www.tensorflow.org/guide/keras>`_, `GStreamer <https://gstreamer.freedesktop.org/>`_, `OpenCV <https://opencv.org/>`_
.. button-link:: https://forum.beagleboard.org/t/enhanced-media-experience-with-ai-powered-commercial-detection-and-replacement/37358
:color: danger
:expand:
.. card:: Embedded differentiable logic gate networks for real-time interactive and creative applications
:fas:`brain;pst-color-secondary` Creative AI :bdg-success:`Medium complexity` :bdg-danger-line:`350 hours`
This project seeks to explore the potential of creative embedded AI, specifically using `Differentiable Logic (DiffLogic) <https://github.com/Felix-Petersen/difflogic>`_, by creating a system that can perform tasks like machine listening, sensor processing, sound and gesture classification, and generative AI.
| **Goal:** Develop an embedded machine learning system on BeagleBone that leverages `Differentiable Logic (DiffLogic) <https://github.com/Felix-Petersen/difflogic>`_ for real-time interactive music creation and environment sensing.
| **Hardware Skills:** Audio and sensor IO with `Bela.io <http://bela.io>`_
| **Software Skills:** Machine learning, deep learning, BeagleBone Programmable Real Time Unit (PRU) programming (see `PRU Cookbook <https://docs.beagleboard.org/latest/books/pru-cookbook/index.html>`_).
| **Possible Mentors:** `Jack Armitage <https://forum.beagleboard.org/u/jarm>`_, `Chris Kiefer <https://forum.beagleboard.org/u/luuma>`_
.. button-link:: https://forum.beagleboard.org/t/embedded-differentiable-logic-gate-networks-for-real-time-interactive-and-creative-applications/37768
:color: danger
:expand:
.. card:: .. card::
:fas:`brain;pst-color-secondary` **YOLO models on the X15/AI-64** :fas:`brain;pst-color-secondary` **YOLO models on the X15/AI-64**
...@@ -3,6 +3,29 @@ ...@@ -3,6 +3,29 @@
FPGA based projects FPGA based projects
.. card:: Low-latency I/O RISC-V CPU core in FPGA fabric
:fas:`microchip;pst-color-primary` FPGA gateware improvements :bdg-success:`Medium complexity` :bdg-success-line:`175 hours`
| **Hardware Skills:** `Verilog`_, `verification`_, `FPGA`_
| **Software Skills:** `RISC-V ISA`_, `assembly`_, `Linux`_
:color: danger
:expand:
.. card:: .. card::
:fas:`microchip;pst-color-secondary` **RISC-V Based PRU on FPGA** :fas:`microchip;pst-color-secondary` **RISC-V Based PRU on FPGA**
...@@ -4,42 +4,21 @@ ...@@ -4,42 +4,21 @@
contain the root `toctree` directive. contain the root `toctree` directive.
:html_theme.sidebar_secondary.remove: true :html_theme.sidebar_secondary.remove: true
GSoC @ BeagleBoard.org GSoC @ BeagleBoard.org
.. image:: _static/images/project-with-beagleboard.webp .. image:: _static/images/project-with-beagleboard.webp
open source developers! The 2024 contributor application window will be open from
`March 18th 2024 <https://developers.google.com/open-source/gsoc/timeline#march_18_-_1800_utc>`_ to
`April 2nd 2024 <https://developers.google.com/open-source/gsoc/timeline#april_2_-_1800_utc>`_!
:width: 100%
:align: center
.. note::
.. grid:: 1 1 1 3 .. grid:: 1 1 1 3
:margin: 4 4 0 0 :margin: 4 4 0 0
:gutter: 4 :gutter: 2
.. grid-item-card:: .. grid-item-card::
:link: https://openbeagle.org/ :link: https://openbeagle.org/
:fab:`gitlab;pst-color-primary` Open Source Development :fab:`gitlab;fa-fade pst-color-dark` Open Source Development
Experience working on impactful open source project which Experience working on impactful open source project which
...@@ -48,7 +27,7 @@ GSoC @ BeagleBoard.org ...@@ -48,7 +27,7 @@ GSoC @ BeagleBoard.org
:link: https://www.beagleboard.org/boards :link: https://www.beagleboard.org/boards
:fas:`microchip;pst-color-primary` Free Hardware :fas:`microchip;fa-fade pst-color-dark` Free Hardware
Recieve BeagleBoard.org open source single board computer, Recieve BeagleBoard.org open source single board computer,
...@@ -57,12 +36,44 @@ GSoC @ BeagleBoard.org ...@@ -57,12 +36,44 @@ GSoC @ BeagleBoard.org
:link: https://developers.google.com/open-source/gsoc/help/student-stipends :link: https://developers.google.com/open-source/gsoc/help/student-stipends
:fas:`sack-dollar;pst-color-primary` Handsome Stipend :fas:`sack-dollar;fa-fade pst-color-dark` Handsome Stipend
Earn while making impactful contributions to the open source Earn while making impactful contributions to the open source
community, Stipend can be upto $6600 based on your country. community, Stipend can be upto $6600 based on your country.
.. image:: _static/images/bash-and-boris-gosc-proposal.webp
.. grid:: 1 1 1 3
:margin: 4 4 0 0
:gutter: 1
.. grid-item::
.. button-ref:: gsoc-contributor-guide
:color: info
:outline:
:expand:
.. grid-item::
.. button-ref:: gsoc-project-ideas
:color: info
:outline:
:expand:
.. grid-item::
.. button-ref:: gsoc-proposal-guide
:color: info
:outline:
:expand:
.. admonition:: Did you know?
.. admonition:: BeagleBoard.org background .. admonition:: BeagleBoard.org background
:class: admonition-clock-back :class: admonition-clock-back
...@@ -84,32 +95,24 @@ GSoC @ BeagleBoard.org ...@@ -84,32 +95,24 @@ GSoC @ BeagleBoard.org
Get inspiration from some :ref:`Past_Projects`. Get inspiration from some :ref:`Past_Projects`.
:gutter: 4 :gutter: 4
.. grid-item-card::
.. youtube:: -giV6Xr8RtY .. grid-item::
:width: 100%
.. grid-item-card:: .. youtube:: -giV6Xr8RtY
:width: 100%
.. youtube:: RWBzyHNetOE .. grid-item::
:width: 100%
.. grid-item-card:: .. youtube:: RWBzyHNetOE
:width: 100%
.. youtube:: CDbEAq33vdA .. grid-item::
:width: 100%
.. important::
:width: 100%
.. admonition:: Some other amazing places to find Beagles .. admonition:: Some other amazing places to find Beagles
:class: hint :class: hint
...@@ -118,25 +121,25 @@ GSoC @ BeagleBoard.org ...@@ -118,25 +121,25 @@ GSoC @ BeagleBoard.org
made cheeseburgers. Check the below projects made by incredible made cheeseburgers. Check the below projects made by incredible
professional innovators for some inspiration. professional innovators for some inspiration.
.. grid:: 1 1 2 2 .. grid:: 1 1 2 2
:fas:`rocket;pst-color-primary` Europa Rover Prototype :fas:`rocket;pst-color-primary` Europa Rover Prototype
.. youtube:: sY5WQG3-3mo .. youtube:: sY5WQG3-3mo
:fas:`burger;pst-color-primary` Cheeseburger Robot :fas:`burger;pst-color-primary` Cheeseburger Robot
.. youtube:: CbL_3le40qc .. youtube:: CbL_3le40qc
.. image:: _static/images/explore-ideas.webp .. image:: _static/images/explore-ideas.webp
.. _gsoc-2024-projects:
:far:`calendar-days` 2024
.. note:: Only 3 out of 4 :ref:`accepted students <gsoc-2024-proposals>` were able to complete the program in 2024.
.. youtube:: Kagg8JycOfo
:width: 100%
| **Summary:** Leveraging the capabilities of BeagleBoard’s powerful processing units, the project will focus on creating a real-time, efficient solution that enhances media consumption experiences by seamlessly integrating custom audio streams during commercial breaks.
- Develop a neural network model: Combine Convolutional Neural Networks (CNNs) and Recurrent Neural Networks (RNNs) to analyze video and audio data, accurately identifying commercial segments within video streams.
- Implement a real-time pipeline: Create a real-time pipeline for BeagleBoard that utilizes the trained model to detect commercials in real-time and replace them with alternative content or obfuscate them, alongside replacing the audio with predefined streams.
- Optimize for BeagleBoard: Ensure the entire system is optimized for real-time performance on BeagleBoard hardware, taking into account its unique computational capabilities and constraints.
**Contributor:** Aryan Nanda
**Mentors:** `Jason Kridner <https://forum.beagleboard.org/u/jkridner>`_, `Deepak Khatri <https://forum.beagleboard.org/u/lorforlinux>`_, Kumar Abhishek
.. grid:: 2 2 2 2
.. grid-item::
.. button-link:: https://summerofcode.withgoogle.com/archive/2024/projects/UOX7iDEU
:color: info
:shadow:
:expand:
:fab:`google;pst-color-light` - GSoC Registry
.. grid-item::
.. button-ref:: gsoc-2024-proposal-aryan-nanda
:color: primary
:shadow:
:expand:
Proposal
.. youtube:: ic0RRK6d3hg
:width: 100%
| **Summary:** Implementation of PRU subsystem on BeagleV-Fire’s FPGA fabric, resulting in a real-time microcontroller system working alongside the main CPU, providing low-latency access to I/O.
**Contributor:** Atharva Kashalkar
**Mentors:** `Cyril Jean <https://forum.beagleboard.org/u/vauban>`_, `Jason Kridner <https://forum.beagleboard.org/u/jkridner>`_, Vedant Paranjape, Kumar Abhishek
.. grid:: 2 2 2 2
.. grid-item::
.. button-link:: https://summerofcode.withgoogle.com/archive/2024/projects/KjUoFlg2
:color: info
:shadow:
:expand:
.. grid-item::
.. button-ref:: gsoc-2024-proposal-roger18
:color: primary
:shadow:
:expand:
Proposal
Differentiable Logic for Interactive Systems and Generative Music - Ian Clester
.. youtube:: NvHxMCF8sAQ
:width: 100%
| **Summary:** Developing an embedded machine learning system on BeagleBoard that leverages Differentiable Logic (DiffLogic) for real-time interactive music creation and environment sensing. The system will enable on-device learning, fine-tuning, and efficient processing for applications in new interfaces for musical expression.
**Contributor:** Ian Clester
**Mentors:** `Jack Armitage <https://forum.beagleboard.org/u/jarm/summary>`_, Chris Kiefer
.. grid:: 2 2 2 2
.. grid-item::
.. button-link:: https://summerofcode.withgoogle.com/archive/2024/projects/FBk0MM8g
:color: info
:shadow:
:expand:
.. grid-item::
.. button-ref:: gsoc-2024-proposal-ijc
:color: primary
:shadow:
:expand:
Proposal
...@@ -14,6 +14,11 @@ GSoC over the previous years is given in the section that follows. ...@@ -14,6 +14,11 @@ GSoC over the previous years is given in the section that follows.
.. grid-item-card:: :far:`calendar-days` 2024
:text-align: center
:link: gsoc-2024-projects
:link-type: ref
.. grid-item-card:: :far:`calendar-days` 2023 .. grid-item-card:: :far:`calendar-days` 2023
:text-align: center :text-align: center
:link: gsoc-2023-projects :link: gsoc-2023-projects
...@@ -74,10 +79,16 @@ GSoC over the previous years is given in the section that follows. ...@@ -74,10 +79,16 @@ GSoC over the previous years is given in the section that follows.
:link: gsoc-2010-projects :link: gsoc-2010-projects
:link-type: ref :link-type: ref
.. admonition:: Explore!
To further explore the contributions made to BeagleBoard.org, you can also visit all the contributions compiled in this `OpenSource Project <https://www.gsocorganizations.dev/organization/beagleboard.org/>`_
by `Nishant Mittal <https://github.com/nishantwrp>`_.
.. toctree:: .. toctree::
:maxdepth: 1 :maxdepth: 1
:hidden: :hidden:
2024
2023 2023
2022 2022
2021 2021
proposals/2024/aryan_nanda/images/Figure1.png
115 KiB
