Commit 963fb461 authored by Maciej Fijalkowski's avatar Maciej Fijalkowski Committed by Tony Nguyen
ice: xsk: fix txq interrupt mapping
ice_cfg_txq_interrupt() internally handles XDP Tx ring. Do not use
ice_for_each_tx_ring() in ice_qvec_cfg_msix() as this causing us to
treat XDP ring that belongs to queue vector as Tx ring and therefore
misconfiguring the interrupts.
Fixes: 2d4238f5
 ("ice: Add support for AF_XDP")
Reviewed-by: default avatarShannon Nelson <shannon.nelson@amd.com>
Tested-by: Chandan Kumar Rout <chandanx.rout@intel.com> (A Contingent Worker at Intel)
Signed-off-by: default avatarMaciej Fijalkowski <maciej.fijalkowski@intel.com>
Signed-off-by: default avatarTony Nguyen <anthony.l.nguyen@intel.com>
parent 6044ca26
...@@ -110,25 +110,29 @@ ice_qvec_dis_irq(struct ice_vsi *vsi, struct ice_rx_ring *rx_ring, ...@@ -110,25 +110,29 @@ ice_qvec_dis_irq(struct ice_vsi *vsi, struct ice_rx_ring *rx_ring,
* ice_qvec_cfg_msix - Enable IRQ for given queue vector * ice_qvec_cfg_msix - Enable IRQ for given queue vector
* @vsi: the VSI that contains queue vector * @vsi: the VSI that contains queue vector
* @q_vector: queue vector * @q_vector: queue vector
* @qid: queue index
static void static void
ice_qvec_cfg_msix(struct ice_vsi *vsi, struct ice_q_vector *q_vector) ice_qvec_cfg_msix(struct ice_vsi *vsi, struct ice_q_vector *q_vector, u16 qid)
u16 reg_idx = q_vector->reg_idx; u16 reg_idx = q_vector->reg_idx;
struct ice_pf *pf = vsi->back; struct ice_pf *pf = vsi->back;
struct ice_hw *hw = &pf->hw; struct ice_hw *hw = &pf->hw;
struct ice_tx_ring *tx_ring; int q, _qid = qid;
struct ice_rx_ring *rx_ring;
ice_cfg_itr(hw, q_vector); ice_cfg_itr(hw, q_vector);
ice_for_each_tx_ring(tx_ring, q_vector->tx) for (q = 0; q < q_vector->num_ring_tx; q++) {
ice_cfg_txq_interrupt(vsi, tx_ring->reg_idx, reg_idx, ice_cfg_txq_interrupt(vsi, _qid, reg_idx, q_vector->tx.itr_idx);
q_vector->tx.itr_idx); _qid++;
ice_for_each_rx_ring(rx_ring, q_vector->rx) _qid = qid;
ice_cfg_rxq_interrupt(vsi, rx_ring->reg_idx, reg_idx,
q_vector->rx.itr_idx); for (q = 0; q < q_vector->num_ring_rx; q++) {
ice_cfg_rxq_interrupt(vsi, _qid, reg_idx, q_vector->rx.itr_idx);
_qid++;
ice_flush(hw); ice_flush(hw);
...@@ -241,7 +245,7 @@ static int ice_qp_ena(struct ice_vsi *vsi, u16 q_idx) ...@@ -241,7 +245,7 @@ static int ice_qp_ena(struct ice_vsi *vsi, u16 q_idx)
fail = err; fail = err;
q_vector = vsi->rx_rings[q_idx]->q_vector; q_vector = vsi->rx_rings[q_idx]->q_vector;
ice_qvec_cfg_msix(vsi, q_vector); ice_qvec_cfg_msix(vsi, q_vector, q_idx);
err = ice_vsi_ctrl_one_rx_ring(vsi, true, q_idx, true); err = ice_vsi_ctrl_one_rx_ring(vsi, true, q_idx, true);
if (!fail) if (!fail)
