Commit 638a91ab authored by Matthias Brugger's avatar Matthias Brugger
brcm: Fix filename for BCM43430 NVRAM for the Raspberry Pi 3 Model B
BCM43430 NVRAM config file for the RPi3 Model B was set to the value
found by brcmf_dmi_probe(), but should use the DT compatible.
Rename the file to actually make it work with the kernel driver.
Signed-off-by: default avatarMatthias Brugger <mbrugger@suse.com>
parent bc656509
