Commit efc58a96 authored by Linus Torvalds's avatar Linus Torvalds
Merge tag 'drm-next-2021-05-10' of git://anongit.freedesktop.org/drm/drm
Pull drm fixes from Dave Airlie:
 "Bit later than usual, I queued them all up on Friday then promptly
  forgot to write the pull request email. This is mainly amdgpu fixes,
  with some radeon/msm/fbdev and one i915 gvt fix thrown in.
  amdgpu:
   - MPO hang workaround
   - Fix for concurrent VM flushes on vega/navi
   - dcefclk is not adjustable on navi1x and newer
   - MST HPD debugfs fix
   - Suspend/resumes fixes
   - Register VGA clients late in case driver fails to load
   - Fix GEM leak in user framebuffer create
   - Add support for polaris12 with 32 bit memory interface
   - Fix duplicate cursor issue when using overlay
   - Fix corruption with tiled surfaces on VCN3
   - Add BO size and stride check to fix BO size verification
  radeon:
   - Fix off-by-one in power state parsing
   - Fix possible memory leak in power state parsing
  msm:
   - NULL ptr dereference fix
  fbdev:
   - procfs disabled warning fix
  i915:
   - gvt: Fix a possible division by zero in vgpu display rate
     calculation"
* tag 'drm-next-2021-05-10' of git://anongit.freedesktop.org/drm/drm:
  drm/amdgpu: Use device specific BO size & stride check.
  drm/amdgpu: Init GFX10_ADDR_CONFIG for VCN v3 in DPG mode.
  drm/amd/pm: initialize variable
  drm/radeon: Avoid power table parsing memory leaks
  drm/radeon: Fix off-by-one power_state index heap overwrite
  drm/amd/display: Fix two cursor duplication when using overlay
  drm/amdgpu: add new MC firmware for Polaris12 32bit ASIC
  fbmem: Mark proc_fb_seq_ops as __maybe_unused
  drm/msm/dpu: Delete bonkers code
  drm/i915/gvt: Prevent divided by zero when calculating refresh rate
  amdgpu: fix GEM obj leak in amdgpu_display_user_framebuffer_create
  drm/amdgpu: Register VGA clients after init can no longer fail
  drm/amdgpu: Handling of amdgpu_device_resume return value for graceful teardown
  drm/amdgpu: fix r initial values
  drm/amd/display: fix wrong statement in mst hpd debugfs
  amdgpu/pm: set pp_dpm_dcefclk to readonly on NAVI10 and newer gpus
  amdgpu/pm: Prevent force of DCEFCLK on NAVI10 and SIENNA_CICHLID
  drm/amdgpu: fix concurrent VM flushes on Vega/Navi v2
  drm/amd/display: Reject non-zero src_y and src_x for video planes
parents 506c3079 0844708a
with 332 additions and 81 deletions
