Commit ef4ef28a authored by William Zhang's avatar William Zhang Committed by Florian Fainelli
tty: serial: bcm63xx: bcmbca: Replace ARCH_BCM_63XX with ARCH_BCMBCA
Prepare for the BCM63138 ARCH_BCM_63XX migration to ARCH_BCMBCA. Make
SERIAL_BCM63XX depending on ARCH_BCMBCA.
Signed-off-by: default avatarWilliam Zhang <william.zhang@broadcom.com>
Acked-by: default avatarFlorian Fainelli <f.fainelli@gmail.com>
Signed-off-by: default avatarFlorian Fainelli <f.fainelli@gmail.com>
parent 16f3c221
...@@ -1099,8 +1099,8 @@ config SERIAL_TIMBERDALE ...@@ -1099,8 +1099,8 @@ config SERIAL_TIMBERDALE
config SERIAL_BCM63XX config SERIAL_BCM63XX
tristate "Broadcom BCM63xx/BCM33xx UART support" tristate "Broadcom BCM63xx/BCM33xx UART support"
select SERIAL_CORE select SERIAL_CORE
depends on ARCH_BCM4908 || ARCH_BCM_63XX || BCM63XX || BMIPS_GENERIC || COMPILE_TEST depends on ARCH_BCM4908 || ARCH_BCMBCA || BCM63XX || BMIPS_GENERIC || COMPILE_TEST
default ARCH_BCM4908 || ARCH_BCM_63XX || BCM63XX || BMIPS_GENERIC default ARCH_BCM4908 || ARCH_BCMBCA || BCM63XX || BMIPS_GENERIC
help help
This enables the driver for the onchip UART core found on This enables the driver for the onchip UART core found on
the following chipsets: the following chipsets:
