Commit d98dba88 authored by Masahiro Yamada's avatar Masahiro Yamada
kbuild: add 'private' to target-specific variables
Currently, Kbuild produces inconsistent results in some cases.
You can do an interesting experiment using the --shuffle option, which
is supported by GNU Make 4.4 or later.
Set CONFIG_KVM_INTEL=y and CONFIG_KVM_AMD=m (or vice versa), and repeat
incremental builds w/wo --shuffle=reverse.
  $ make
    [ snip ]
    CC      arch/x86/kvm/kvm-asm-offsets.s
  $ make --shuffle=reverse
    [ snip ]
    CC [M]  arch/x86/kvm/kvm-asm-offsets.s
  $ make
    [ snip ]
arch/x86/kvm/kvm-asm-offsets.s is rebuilt every time w/wo the [M] marker.
arch/x86/kvm/kvm-asm-offsets.s is built as built-in when it is built as
a prerequisite of arch/x86/kvm/kvm-intel.o, which is built-in.
arch/x86/kvm/kvm-asm-offsets.s is built as modular when it is built as
a prerequisite of arch/x86/kvm/kvm-amd.o, which is a module.
Another odd example is single target builds.
When CONFIG_LKDTM=m, drivers/misc/lkdtm/rodata.o can be built as
built-in or modular, depending on how it is built.
  $ make drivers/misc/lkdtm/lkdtm.o
    [ snip ]
    CC [M]  drivers/misc/lkdtm/rodata.o
  $ make drivers/misc/lkdtm/rodata.o
    [ snip ]
    CC      drivers/misc/lkdtm/rodata.o
drivers/misc/lkdtm/rodata.o is built as modular when it is built as a
prerequisite of another, but built as built-in when it is a final
target.
The same thing happens to drivers/memory/emif-asm-offsets.s when
CONFIG_TI_EMIF_SRAM=m.
  $ make drivers/memory/ti-emif-sram.o
    [ snip ]
    CC [M]  drivers/memory/emif-asm-offsets.s
  $ make drivers/memory/emif-asm-offsets.s
    [ snip ]
    CC      drivers/memory/emif-asm-offsets.s
This is because the part-of-module=y flag defined for the modules is
inherited by its prerequisites.
Target-specific variables are likely intended only for local use.
This commit adds 'private' to them.
Signed-off-by: default avatarMasahiro Yamada <masahiroy@kernel.org>
Reviewed-by: default avatarNicolas Schier <n.schier@avm.de>
parent 770202a2
