crypto: ecc - Actually remove stack VLA usage
On the quest to remove all VLAs from the kernel[1], this avoids VLAs by just using the maximum allocation size (4 bytes) for stack arrays. All the VLAs in ecc were either 3 or 4 bytes (or a multiple), so just make it 4 bytes all the time. Initialization routines are adjusted to check that ndigits does not end up larger than the arrays. This includes a removal of the earlier attempt at this fix from commit a963834b4742 ("crypto/ecc: Remove stack VLA usage") [1] https://lkml.org/lkml/2018/3/7/621 Signed-off-by:Kees Cook <keescook@chromium.org> Signed-off-by:
Herbert Xu <herbert@gondor.apana.org.au>
Please register or sign in to comment
