Commit d2be38b9 authored by Linus Torvalds's avatar Linus Torvalds
Merge tag 'mips_6.11' of git://git.kernel.org/pub/scm/linux/kernel/git/mips/linux
Pull MIPS updates from Thomas Bogendoerfer:
 - add support for Realtek RTL9302C
 - add support for Mobileye EyeQ6H
 - add support for Mobileye EyeQ OLB system controller
 - improve r4k clocksource
 - add mode for emulating ieee754 NAN2008
 - rework for BMIPS CBR address handling
 - fixes for Loongson 2K1000
 - defconfig updates
 - cleanups and fixes
* tag 'mips_6.11' of git://git.kernel.org/pub/scm/linux/kernel/git/mips/linux: (58 commits)
  MIPS: config: Add ip30_defconfig
  MIPS: config: lemote2f: Regenerate defconfig
  MIPS: config: generic: Add board-litex
  MIPS: config: Enable MSA and virtualization for MIPS64R6
  MIPS: Fix fallback march for SB1
  mips: dts: realtek: Add RTL9302C board
  mips: generic: add fdt fixup for Realtek reference board
  mips: select REALTEK_OTTO_TIMER for Realtek platforms
  dt-bindings: interrupt-controller: realtek,rtl-intc: Add rtl9300-intc
  dt-bindings: mips: realtek: Add rtl930x-soc compatible
  dt-bindings: vendor-prefixes: Add Cameo Communications
  mips: dts: realtek: add device_type property to cpu node
  mips: dts: realtek: use "serial" instead of "uart" in node name
  MIPS: Implement ieee754 NAN2008 emulation mode
  MIPS: lantiq: improve USB initialization
  MIPS: GIC: Generate redirect block accessors
  MIPS: CPS: Add a couple of multi-cluster utility functions
  MIPS: Octeron: remove source file executable bit
  MAINTAINERS: Mobileye: add OLB drivers and dt-bindings
  MIPS: mobileye: eyeq5: add OLB system-controller node
parents 3c3ff7be bb2d6350
with 548 additions and 54 deletions
