ata: ahci_brcm: Fix AHCI resources management
The AHCI resources management within ahci_brcm.c is a little convoluted, largely because it historically had a dedicated clock that was managed within this file in the downstream tree. Once brough upstream though, the clock was left to be managed by libahci_platform.c which is entirely appropriate. This patch series ensures that the AHCI resources are fetched and enabled before any register access is done, thus avoiding bus errors on platforms which clock gate the controller by default. As a result we need to re-arrange the suspend() and resume() functions in order to avoid accessing registers after the clocks have been turned off respectively before the clocks have been turned on. Finally, we can refactor brcm_ahci_get_portmask() in order to fetch the number of ports from hpriv->mmio which is now accessible without jumping through hoops like we used to do. The commit pointed in the Fixes tag is both old and new enough not to require major headaches for backporting of this patch. Fixes: eba68f82 ("ata: ahci_brcmstb: rename to support across Broadcom SoC's") Cc: stable@vger.kernel.org Reviewed-by:Hans de Goede <hdegoede@redhat.com> Signed-off-by:
Florian Fainelli <f.fainelli@gmail.com> Signed-off-by:
Jens Axboe <axboe@kernel.dk>
Please register or sign in to comment
