Commit 9919cce6 authored by Kent Gibson's avatar Kent Gibson Committed by Bartosz Golaszewski
gpiolib: cdev: Disallow reconfiguration without direction (uAPI v1)
linehandle_set_config() behaves badly when direction is not set.
The configuration validation is borrowed from linehandle_create(), where,
to verify the intent of the user, the direction must be set to in order
to effect a change to the electrical configuration of a line. But, when
applied to reconfiguration, that validation does not allow for the unset
direction case, making it possible to clear flags set previously without
specifying the line direction.
Adding to the inconsistency, those changes are not immediately applied by
linehandle_set_config(), but will take effect when the line value is next
get or set.
For example, by requesting a configuration with no flags set, an output
line with GPIOHANDLE_REQUEST_ACTIVE_LOW and GPIOHANDLE_REQUEST_OPEN_DRAIN
requested could have those flags cleared, inverting the sense of the line
and changing the line drive to push-pull on the next line value set.
Ensure the intent of the user by disallowing configurations which do not
have direction set, returning an error to userspace to indicate that the
configuration is invalid.
And, for clarity, use lflags, a local copy of gcnf.flags, throughout when
dealing with the requested flags, rather than a mixture of both.
Fixes: e588bb1e
 ("gpio: add new SET_CONFIG ioctl() to gpio chardev")
Signed-off-by: default avatarKent Gibson <warthog618@gmail.com>
Link: https://lore.kernel.org/r/20240626052925.174272-2-warthog618@gmail.com
Signed-off-by: default avatarBartosz Golaszewski <bartosz.golaszewski@linaro.org>
parent 88811957
