Commit 7ddb4cc2 authored by Zou Wei's avatar Zou Wei Committed by Dan Williams
tools/testing/nvdimm: Make symbol '__nfit_test_ioremap' static
The sparse tool complains as follows:
tools/testing/nvdimm/test/iomap.c:65:14: warning:
 symbol '__nfit_test_ioremap' was not declared. Should it be static?
This symbol is not used outside of iomap.c, so this
commit marks it static.
Reported-by: default avatarHulk Robot <hulkci@huawei.com>
Signed-off-by: default avatarZou Wei <zou_wei@huawei.com>
Link: https://lore.kernel.org/r/1618904867-25275-1-git-send-email-zou_wei@huawei.com
Signed-off-by: default avatarDan Williams <dan.j.williams@intel.com>
parent 681865a0
...@@ -62,7 +62,7 @@ struct nfit_test_resource *get_nfit_res(resource_size_t resource) ...@@ -62,7 +62,7 @@ struct nfit_test_resource *get_nfit_res(resource_size_t resource)
EXPORT_SYMBOL(get_nfit_res); EXPORT_SYMBOL(get_nfit_res);
void __iomem *__nfit_test_ioremap(resource_size_t offset, unsigned long size, static void __iomem *__nfit_test_ioremap(resource_size_t offset, unsigned long size,
void __iomem *(*fallback_fn)(resource_size_t, unsigned long)) void __iomem *(*fallback_fn)(resource_size_t, unsigned long))
struct nfit_test_resource *nfit_res = get_nfit_res(offset); struct nfit_test_resource *nfit_res = get_nfit_res(offset);
