Commit 35344cf3 authored by Taehee Yoo's avatar Taehee Yoo Committed by Herbert Xu
crypto: x86/aria - do not use magic number offsets of aria_ctx
aria-avx assembly code accesses members of aria_ctx with magic number
offset. If the shape of struct aria_ctx is changed carelessly,
aria-avx will not work.
So, we need to ensure accessing members of aria_ctx with correct
offset values, not with magic numbers.
It adds ARIA_CTX_enc_key, ARIA_CTX_dec_key, and ARIA_CTX_rounds in the
asm-offsets.c So, correct offset definitions will be generated.
aria-avx assembly code can access members of aria_ctx safely with
these definitions.
Signed-off-by: default avatarTaehee Yoo <ap420073@gmail.com>
Signed-off-by: default avatarHerbert Xu <herbert@gondor.apana.org.au>
parent 8e7d7ce2
