Commit 291e4baf authored by Zenghui Yu's avatar Zenghui Yu Committed by Daniel Vetter
kselftests: dmabuf-heaps: Ensure the driver name is null-terminated
Even if a vgem device is configured in, we will skip the import_vgem_fd()
test almost every time.
  TAP version 13
  1..11
  # Testing heap: system
  # Testing allocation and importing:
  ok 1 # SKIP Could not open vgem -1
The problem is that we use the DRM_IOCTL_VERSION ioctl to query the driver
version information but leave the name field a non-null-terminated string.
Terminate it properly to actually test against the vgem device.
While at it, let's check the length of the driver name is exactly 4 bytes
and return early otherwise (in case there is a name like "vgemfoo" that
gets converted to "vgem\0" unexpectedly).
Signed-off-by: default avatarZenghui Yu <yuzenghui@huawei.com>
Signed-off-by: default avatarDaniel Vetter <daniel.vetter@ffwll.ch>
Link: https://patchwork.freedesktop.org/patch/msgid/20240729024604.2046-1-yuzenghui@huawei.com
parent b6f7d984
