tracing: relax trace_event_eval_update() execution with cond_resched()
When kernel is compiled without preemption, the eval_map_work_func() (which calls trace_event_eval_update()) will not be preempted up to its complete execution. This can actually cause a problem since if another CPU call stop_machine(), the call will have to wait for the eval_map_work_func() function to finish executing in the workqueue before being able to be scheduled. This problem was observe on a SMP system at boot time, when the CPU calling the initcalls executed clocksource_done_booting() which in the end calls stop_machine(). We observed a 1 second delay because one CPU was executing eval_map_work_func() and was not preempted by the stop_machine() task. Adding a call to cond_resched() in trace_event_eval_update() allows other tasks to be executed and thus continue working asynchronously like before without blocking any pending task at boot time. Link: https://lore.kernel.org/linux-trace-kernel/20230929191637.416931-1-cleger@ri...
Please register or sign in to comment
