Commit 16bae3e1 authored by Paul Moore's avatar Paul Moore Committed by Jens Axboe
io_uring: enable audit and restrict cred override for IORING_OP_FIXED_FD_INSTALL
We need to correct some aspects of the IORING_OP_FIXED_FD_INSTALL
command to take into account the security implications of making an
io_uring-private file descriptor generally accessible to a userspace
task.
The first change in this patch is to enable auditing of the FD_INSTALL
operation as installing a file descriptor into a task's file descriptor
table is a security relevant operation and something that admins/users
may want to audit.
The second change is to disable the io_uring credential override
functionality, also known as io_uring "personalities", in the
FD_INSTALL command.  The credential override in FD_INSTALL is
particularly problematic as it affects the credentials used in the
security_file_receive() LSM hook.  If a task were to request a
credential override via REQ_F_CREDS on a FD_INSTALL operation, the LSM
would incorrectly check to see if the overridden credentials of the
io_uring were able to "receive" the file as opposed to the task's
credentials.  After discussions upstream, it's difficult to imagine a
use case where we would want to allow a credential override on a
FD_INSTALL operation so we are simply going to block REQ_F_CREDS on
IORING_OP_FIXED_FD_INSTALL operations.
Fixes: dc18b89a
 ("io_uring/openclose: add support for IORING_OP_FIXED_FD_INSTALL")
Signed-off-by: default avatarPaul Moore <paul@paul-moore.com>
Link: https://lore.kernel.org/r/20240123215501.289566-2-paul@paul-moore.com
Signed-off-by: default avatarJens Axboe <axboe@kernel.dk>
parent 6613476e
