  • docs/docs.beagleboard.io
  • jkridner/docs
  • lorforlinux/docs.beagleboard.io
  • harshilbhatt2001/docs.beagleboard.io
  • Krishna_13/docs.beagleboard.io
  • gpioblink/docs.beagleboard.io
  • dhruvag2000/docs.beagleboard.io
  • jiande/docs.beagleboard.io
  • beagleplay/docs
  • beaglev-ahead/docs
  • sabeeh.khan14/docs.beagleboard.io
  • yoder/docs.beagleboard.io
  • jdneal/docs.beagleboard.io
  • ayush1325/docs.beagleboard.io
  • vishnumaiea/docs.beagleboard.io
  • andrei1998/docs-beagleboard-io-zephyr-demo
  • andrei1998/docs.beagleboard.io
  • nmenon/docs.beagleboard.io
  • epenguin/docs.beagleboard.io
  • paul_buxton/docs.beagleboard.io
  • anujdeshpande/docs.beagleboard.io
  • melta101/docs.beagleboard.io
  • krvprashanth/docs.beagleboard.io
  • samdai/docs.beagleboard.io
  • bustedwing1/docs.beagleboard.io
  • cshegedus/docs.beagleboard.io
  • wmat/docs.beagleboard.io
  • Roger18/docs.beagleboard.io
  • himanshuk/docs.beagleboard.io
  • vvaishak/docs.beagleboard.io
  • alecdenny/docs.beagleboard.io
  • san.s.kar03/docs.beagleboard.io
  • andrei1998/docs-beagleboard-io-fixes
  • SomeInterestingUserName/docs.beagleboard.io
  • edge-ai/docs
  • andrei1998/docs-beagleboard-io-rtc
  • devarsht/docs.beagleboard.io
  • andrei1998/docs-beagleboard-io-deepak-fork
  • superchamp234/docs.beagleboard.io
  • lranders/docs.beagleboard.io
  • kushalkr/docs.beagleboard.io
  • mkorpershoek/docs.beagleboard.io
  • prajnark/docs.beagleboard.io
  • touchhowling/docs.beagleboard.io
  • RobertCNelson/docs.beagleboard.io
  • Shankari02/docs.beagleboard.io
  • LucienMorey/docs.beagleboard.io
  • ketanthorat/docs.beagleboard.io
  • jjateen/docs.beagleboard.io
  • Whiz-Manas/mana-docs-beagleboard-io
  • beagley-ai/zephyr/docs.beagleboard.io
  • giuliomoro/docs.beagleboard.io
52 results
Commits on Source (1929)
with 643 additions and 42 deletions
...@@ -10,7 +10,7 @@ ...@@ -10,7 +10,7 @@
cscope.* cscope.*
.dir .dir
*.diff
/*.patch /*.patch
# The .cache directory will be used to cache toolchain capabilities if # The .cache directory will be used to cache toolchain capabilities if
# You can override the included template(s) by including variable overrides image: registry.git.beagleboard.org/docs/sphinx-build-env:latest
# SAST customization: https://docs.gitlab.com/ee/user/application_security/sast/#customizing-the-sast-settings
# Secret Detection customization: https://docs.gitlab.com/ee/user/application_security/secret_detection/#customizing-settings
# Dependency Scanning customization: https://docs.gitlab.com/ee/user/application_security/dependency_scanning/#customizing-the-dependency-scanning-settings
# Note that environment variables can be set in several places
# See https://docs.gitlab.com/ee/ci/variables/#cicd-variable-precedence
image: beagle/sphinx-build-env:latest
variables: variables:
GIT_SUBMODULE_STRATEGY: recursive GIT_SUBMODULE_STRATEGY: recursive
cache: cache:
key: bbdocs key: sphinx-build-env-docs-003
paths: paths:
- public - .venv
- .cache
build:
stage: build
tags:
- docker-amd64
parallel:
matrix:
- TARGET: [html, pdf]
artifacts:
paths:
- public/$TARGET
before_script:
- source ./venv-build-env.sh
script:
- ./gitlab-build.sh $TARGET
pages: pages:
stage: deploy stage: deploy
dependencies:
- "build: [html]"
- "build: [pdf]"
tags:
- docker-amd64
script:
- ./gitlab-build.sh publish
artifacts:
paths:
- public
except:
- tags
docs:
stage: deploy
dependencies:
- "build: [html]"
- "build: [pdf]"
tags:
- docker-amd64
script: script:
- "./gitlab-build.sh" - ./gitlab-build.sh publish
artifacts: artifacts:
paths: paths:
- public - public
only:
- tags
except:
- branches
[submodule "books/beaglebone-cookbook/code"] [submodule "books/beaglebone-cookbook/code"]
path = books/beaglebone-cookbook/code path = books/beaglebone-cookbook/code
url = https://git.beagleboard.org/beagleboard/beaglebone-cookbook-code.git url = https://openbeagle.org/beagleboard/beaglebone-cookbook-code.git
[submodule "books/pru-cookbook/code"]
path = books/pru-cookbook/code
url = https://openbeagle.org/beagleboard/pru-cookbook-code
[submodule "projects/librobotcontrol"]
path = projects/librobotcontrol
url = https://openbeagle.org/beagleboard/librobotcontrol
.. _contributors:
Contributors
This is a list of people who have made contributions to BeagleBoard.org unified documentation project.
People are listed alphabetically, as verified with Unix sort:
.. code-block:: shell
$ grep "^- " CONTRIB.rst | LC_ALL=C sort -u -c -f
This is certainly not comprehensive, and if you've been overlooked (sorry!), please open an issue on GitLab or mention it on the forum.
- `Andrei Aldea <https://git.beagleboard.org/andrei1998>`_
- `Ayush Singh <https://git.beagleboard.org/ayush1325>`_
- `Cathy Wicks <https://forum.beagleboard.org/u/cwicks>`_
- `Deepak Khatri <https://git.beagleboard.org/lorforlinux>`_
- `Dhruva Gole <https://git.beagleboard.org/dhruvag2000>`_
- `Gerald Coley <https://www.linkedin.com/in/gerald-coley-b0b3535/>`_
- `Harshil Bhatt <https://git.beagleboard.org/harshilbhatt2001>`_
- `Jason Kridner <https://git.beagleboard.org/jkridner/>`_
- `Jian De <https://git.beagleboard.org/jiande>`_
- `Joshua Neal <https://git.beagleboard.org/jdneal>`_
- `Kai Yamada <https://git.beagleboard.org/gpioblink>`_
- `Krishna Narayanan <https://git.beagleboard.org/Krishna_13>`_
- `Mark A. Yoder <https://git.beagleboard.org/yoder>`_
- `Robert Nelson <https://git.beagleboard.org/RobertCNelson>`_
- `Robert P J Day <https://github.com/rpjday>`_
- `Sabeeh Khan <https://git.beagleboard.org/sabeeh.khan14>`_
- `Seth N <https://git.beagleboard.org/silver2row>`_
\ No newline at end of file
...@@ -7,15 +7,66 @@ the BeagleBoard.org Foundation at https://git.beagleboard.org/docs/docs.beaglebo ...@@ -7,15 +7,66 @@ the BeagleBoard.org Foundation at https://git.beagleboard.org/docs/docs.beaglebo
mostly guidelines, not rules. Use your best judgment, and feel free to propose changes to this mostly guidelines, not rules. Use your best judgment, and feel free to propose changes to this
document in a pull request. document in a pull request.
## Code of Conduct ## Contribution
This project and everyone participating in it is governed by Contributions in any form are appreciated. If you want to contribute to the docs but not sure
the [BeagleBoard.org Code of Conduct](CODE_OF_CONDUCT.md). By participating, you are expected to where to start then you can checkout our contribution documents to help you with your first pull request.
uphold this code. Please report unacceptable behavior to [coc@bbb.io](mailto:coc@bbb.io) or
contact one of the administrators on https://forum.beagleboard.org. ### Code of Conduct
This project and everyone participating in it is governed by the [BeagleBoard.org Code of Conduct](https://docs.beagleboard.org/latest/intro/contribution/code-of-conduct.html). By participating, you are expected to uphold this code. Please report unacceptable behavior to [coc@bbb.io](mailto:coc@bbb.io) or contact one of the administrators on https://forum.beagleboard.org.
### Style and usage guidelines
If you are new to Sphinx, RST, or git then you can checkout out our [How can I contribute? guide](https://docs.beagleboard.org/latest/intro/contribution/how.html).
See more at https://docs.beagleboard.org/latest/intro/contribution/.
### Forking the Project
You can [fork](https://openbeagle.org/help/user/project/repository/forking_workflow.md) this project repository to create and submit changes to the documentation. BeagleBoard documentation is generated using [**Sphinx** ](https://www.sphinx-doc.org/en/master/) documentation tool. Sphinx uses the [**reStructuredText**](https://docutils.sourceforge.io/rst.html) (.rst) markup language by default. Some files are also written in [**Markdown**](https://docs.gitlab.com/ee/user/markdown.html) (.md) format. GitLab can render previews for both RST and MD files. So if you do not want to use any external tools to edit the documentation, you can do that within your browser and use the `Preview` button in GitLab to view how the changes will actually look like.
#### Using A Browser
Using a browser is the easiest way to contribute to this project, if you are a beginner, or if your suggestions for changes are small. Though, some Git version control knowledge is preferrable. You can learn more about [Git and GitLab from here](https://openbeagle.org/help/topics/git/index.md).
You can create a fork of this repository to your GitLab account using the `Forks` button found on the main page of the project. This will create a stand-alone copy of the repository for you to work with.
You can now edit the files without affecting the original project repository. After making the changes, you can commit (save) them and initiate a pull-request. One of the maintainers will review your changes and if accepted, will merge your changes with the original project.
#### In Local Machine
Another method is to clone the forked project into local computer and make the edits from there. If you want to take advantage of the powerful editing features of a modern IDE for writing documentation, we suggest using [**Visual Studio Code**](https://code.visualstudio.com/) for it. With an IDE, you will get syntax highlighting, linting, code completion, IntelliSense, and live preview among other things. Depending on your operating system, you need to install the following softwares or packages.
- [Visual Studio Code](https://code.visualstudio.com/)
- [Python 3](https://www.python.org/downloads/)
- [Python Extension](https://marketplace.visualstudio.com/items?itemName=ms-python.python)
- [reStructuredText Extension](https://marketplace.visualstudio.com/items?itemName=lextudio.restructuredtext)
The reStructuredText extension provides rich reStructuredText language support for VS Code. It will install everything required to work with RST files. If you are prompted for installing other recommended extensions or tools such as Python packages, just continue with their installs. The extension will also install the **Esbonio** language server for showing document previews right on the IDE.
Open the terminal of your choice and run the following command to clone the forked project to your computer. The project is saved to the location where the terminal is opened from. If you want to change the location, use `cd` command to change the directory.
git clone <your forked repository link>
Additionally, you can use the `Clone Repository` function of VS Code and paste the URL there. Wait until all of the project files are downloaded. A folder with the name `docs.beagleboard.io` will be created. You need to enter into the directory with the `cd` command. After that, you can launch VS Code from the terminal with the following command.
code .
This will open the project folder as a workspace in VS Code. If you have all the necessary tools installed, you will see an `esbonio:` status button on the status bar of VS Code. You can click it to build the Sphinx project. The build log will be printed to the `OUTPUT` window of VS Code. If you run into any issues, the output log is the place you want to look at to see what went wrong.
![Successful build of BeagleBoard docs in VS Code](/_images/BeagleBoard-Docs-on-VS-Code-Sphinx-Build-Successful.png "Successful build of BeagleBoard docs in VS Code")
VS Code is not limited to running from a folder as a workspace, or as a native application. It can run on your browser or use a remote directory as the workspace. For example, if you are on Windows 11, you can host your project on [**WSL**](https://learn.microsoft.com/en-us/windows/wsl/about) (Windows Subsystem for Linux), run an instance of VS Code in your Windows, and connect to the repository residing in the WSL. You can learn more about this from the [VS Code docs](https://code.visualstudio.com/docs/remote/wsl). This is useful if you do not want to change your main operating system to a GNU/Linux distro but still want to work with Linux-based tools.
## FAQ ## FAQ
* [Frequently Asked Questions category on the BeagleBoard.org Forum](https://forum.beagleboard.org/c/faq/19) * [Frequently Asked Questions category on the BeagleBoard.org Forum](https://forum.beagleboard.org/c/faq)
## Feedback
See more at https://docs.beagleboard.org/en/latest/intro/contribution/. * [Site Feedback category on the BeagleBoard.org Forum](https://forum.beagleboard.org/c/site-feedback)
FROM python:3.9-alpine as sphinx-build-env
RUN apk update
RUN python -m pip install --upgrade pip
RUN pip install -U sphinx
RUN pip install -U sphinx_design
RUN pip install sphinxcontrib-svg2pdfconverter
RUN apk add librsvg
RUN pip install sphinx_rtd_theme
RUN apk add texlive-full
RUN apk add make
RUN apk add rsync
RUN apk add git
...@@ -12,9 +12,19 @@ BUILDDIR = _build ...@@ -12,9 +12,19 @@ BUILDDIR = _build
help: help:
@$(SPHINXBUILD) -M help "$(SOURCEDIR)" "$(BUILDDIR)" $(SPHINXOPTS) $(O) @$(SPHINXBUILD) -M help "$(SOURCEDIR)" "$(BUILDDIR)" $(SPHINXOPTS) $(O)
.PHONY: help Makefile submodule:
git submodule update --init
git pull
librobotcontrol:
cd projects/librobotcontrol/docs/ ; doxygen
livehtml:
sphinx-autobuild "$(SOURCEDIR)" "$(BUILDDIR)" $(SPHINXOPTS) $(O)
.PHONY: help Makefile submodule librobotcontrol
# Catch-all target: route all unknown targets to Sphinx using the new # Catch-all target: route all unknown targets to Sphinx using the new
# "make mode" option. $(O) is meant as a shortcut for $(SPHINXOPTS). # "make mode" option. $(O) is meant as a shortcut for $(SPHINXOPTS).
%: Makefile %: Makefile
@$(SPHINXBUILD) -M $@ "$(SOURCEDIR)" "$(BUILDDIR)" $(SPHINXOPTS) $(O) $(SPHINXBUILD) -M $@ "$(SOURCEDIR)" "$(BUILDDIR)" $(SPHINXOPTS) $(O)
VERSION_MAJOR = 0
VERSION_MINOR = 0
PATCHLEVEL = 9
VERSION_TWEAK = 4
EXTRAVERSION = rc4
281 KiB
.wy-side-nav-search > a img.logo { .wy-side-nav-search>a img.logo {
width: 340px; width: 340px;
height: 66px; height: 66px;
.rst-content div.figure, .rst-content figure { .rst-content div.figure,
text-align: center; text-align: center;
...@@ -36,7 +37,7 @@ ...@@ -36,7 +37,7 @@
background-color: #25282b; background-color: #25282b;
.wy-nav-top{ .wy-nav-top {
...@@ -62,10 +63,80 @@ ...@@ -62,10 +63,80 @@
/* Force table content font-size in responsive tables to be 100% /* Force table content font-size in responsive tables to be 100%
* fixing larger font size for paragraphs in the kconfig tables */ * fixing larger font size for paragraphs in the kconfig tables */
.wy-table-responsive td p { .wy-table-responsive td p {
font-size: 100%; font-size: 100%;
span.strike { span.strike {
text-decoration: line-through; text-decoration: line-through;
.admonition-license-terms.admonition {
overflow: auto;
/* Site horizontal spacing */
.bd-main .bd-content .bd-article-container {
max-width: 120em;
/* default is 60em */
.bd-page-width {
max-width: 120rem;
/* default is 88rem */
/* Figure headerlink */
figure a.headerlink {
position: static;
/* Primary sidebar toggle button */
#pst-primary-sidebar.collapsed {
overflow: hidden;
padding: 0;
width: 0; /* Collapse the sidebar */
transition: none;
#pst-secondary-sidebar.collapsed {
overflow: hidden;
padding: 0;
transition: none;
#pst-secondary-sidebar {
padding-left: 0px;
/* Toggle button styles */
.sidebar-toggle-btn {
margin-top: 44px; /* Space between sidebar and button */
padding: 7px; /* Set padding for the button, horizontally more */
background-color: #F16321; /* Button background color */
color: white; /* Text color */
border: none; /* Remove border */
cursor: pointer; /* Pointer cursor on hover */
display: block; /* Ensure the button is block-level */
font-size: 20px; /* Adjust font size */
font-weight: bold; /* Bold text */
height: 40px; /* Set a fixed height for the button */
width: auto; /* Width based on content */
line-height: 20px; /* Vertically center the text */
#toggle-primary-sidebar.sidebar-toggle-btn{
border-radius: 0 5px 5px 0; /* Rounded corners */
#toggle-secondary-sidebar.sidebar-toggle-btn{
border-radius: 5px 0 0 5px; /* Rounded corners */
/* Optional: Adding a hover effect */
.sidebar-toggle-btn:hover {
background-color: #C7480D; /* Slightly darker blue on hover */
.. Latest distro images
.. Created on: 2023-11-17
.. Updated on: 2023-11-17
.. _BeaglePlay latest image (Xfce): https://www.beagleboard.org/distros/beagleplay-11-8-2023-10-07-10gb-emmc-xfce-flasher
.. _BeaglePlay latest image (home-assistant): https://www.beagleboard.org/distros/beagleplay-11-8-2023-10-07-8gb-emmc-home-assistant-flasher
.. _AM57xx latest image (IoT): https://www.beagleboard.org/distros/am57xx-12-2-2023-10-07-4gb-emmc-iot-flasher
.. _AM57xx latest image (Xfce): https://www.beagleboard.org/distros/am57xx-11-7-2023-09-02-4gb-emmc-xfce-flasher
.. _BeagleBone AI-64 latest image (Minimal): https://www.beagleboard.org/distros/bbai64-12-2-2023-10-07-6gb-emmc-minimal-flasher
.. _BeagleBone AI-64 latest image (TI EDGEAI): https://www.beagleboard.org/distros/bbai64-11-8-2023-10-07-10gb-emmc-ti-edgeai-xfce-flasher
.. _BeagleBone AI-64 latest image (Xfce): https://www.beagleboard.org/distros/bbai64-11-8-2023-10-07-10gb-emmc-xfce-flasher
.. _AM335x latest image: https://www.beagleboard.org/distros/am335x-11-7-2023-09-02-4gb-microsd-iot
.. _AM335x latest image (Xfce): https://www.beagleboard.org/distros/am335x-11-7-2023-09-02-4gb-emmc-xfce-flasher
.. _AM335x latest image (IoT): https://www.beagleboard.org/distros/am335x-11-7-2023-09-02-4gb-emmc-iot-flasher
.. _BeagleConnect Freedom latest image (micropython): https://www.beagleboard.org/distros/beagleconnect-freedom-micropython-v0-0-3
.. _BeagleV-Ahead latest image (Ubuntu): https://www.beagleboard.org/distros/beaglev-ahead-ubuntu-2023-07-05
.. _BeagleV-Ahead latest image (Yocto): https://www.beagleboard.org/distros/beaglev-ahead-yocto-npi-2023-06-10
.. Production board boot media
.. Created on: 2024-03-22
.. Updated on: 2024-04-12
.. Add BeagleBone AI Rev -
.. Add BeagleBone Blue Rev -
.. Add BeagleV-Fire Rev -
.. _BeaglePlay Rev A2: https://www.beagleboard.org/distros/beagleplay-rev-a2
.. _BeagleBone AI-64 Rev B1: https://www.beagleboard.org/distros/beaglebone-ai-64-rev-b1
.. _BeagleBone Black Rev C3a: https://www.beagleboard.org/distros/am3358-debian-10-3-2020-04-06-4gb-sd-iot
.. _BeagleBone Black Industrial Rev C3a: https://www.beagleboard.org/distros/am3358-debian-10-3-2020-04-06-4gb-sd-iot
.. _BeagleV-Ahead Rev 1.0: https://www.beagleboard.org/distros/beaglev-ahead-rev-1-0
.. _PocketBeagle Rev Rev A2b: https://www.beagleboard.org/distros/am3358-debian-10-3-2020-04-06-4gb-sd-iot
.. _BeagleConnect Freedom Rev C7: https://www.beagleboard.org/distros/beagleconnect-freedom-rev-c7
_static/images/banner.webp
447 KiB
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<svg
viewBox="0 0 242.59765 331.54002"
version="1.1"
id="svg38"
sodipodi:docname="boris.svg"
width="242.59766"
height="331.54001"
inkscape:version="1.3 (0e150ed6c4, 2023-07-21)"
xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
xmlns="http://www.w3.org/2000/svg"
xmlns:svg="http://www.w3.org/2000/svg"
xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
xmlns:cc="http://creativecommons.org/ns#"
xmlns:dc="http://purl.org/dc/elements/1.1/">
<defs
id="defs38" />
<sodipodi:namedview
id="namedview38"
pagecolor="#ffffff"
bordercolor="#000000"
borderopacity="0.25"
inkscape:showpageshadow="2"
inkscape:pageopacity="0.0"
inkscape:pagecheckerboard="0"
inkscape:deskcolor="#d1d1d1"
inkscape:zoom="0.17894989"
inkscape:cx="1114.8373"
inkscape:cy="514.11041"
inkscape:window-width="1536"
inkscape:window-height="790"
inkscape:window-x="0"
inkscape:window-y="0"
inkscape:window-maximized="1"
inkscape:current-layer="svg38" />
<title
id="title1">beagleboard-logo</title>
<path
d="m 235.56773,129.68 c 5.43,-29.68 -19.96,-53.31 -58.57,-66.55 -10.4,-36.77 -33.92,-58.63 -68.33,-58.63 -19.999997,0 -37.739997,7.84 -49.139997,20 -25.6,1.6 -25.78,31.73 -48.13,74.81 -17.4899997,33.74 -3.7299997,68.69 38.48,74.11 -6.59,15.25 -10,32.92 -10.34,50.77 -21.41,-24.53 -15.54,-49.87 -27.54,-49.19 -14.9999997,0.83 4.19,54 30.81,83.64 a 133,133 0 0 0 3.98,14.36 c -9.29,3.21 -19,12.84 -19,24 0,12.7 8.7,13.88 20,14 a 20.85,20.85 0 0 0 -0.59,4.46 10.38,10.38 0 0 0 4,8.59 c 2.84,2.16 6.87,3.25 12.5,3.46 0.82,0 1.63,0 2.42,0 v 0 c 11.9,0 20.08,-3.33 25.25,-8 a 21.22,21.22 0 0 0 7.25,-15.51 15.26,15.26 0 0 0 -0.42,-3.64 17.81,17.81 0 0 1 -0.35,-2 168.68,168.68 0 0 1 28.879997,-0.18 c -0.14,1 -0.27,1.77 -0.38,2.21 a 14,14 0 0 0 -0.39,3.36 c 0,4.91 2.24,10.87 7.6,15.63 5.36,4.76 13.78,8.16 25.85,8.16 v 0 c 0.79,0 1.6,0 2.42,0 5.49,-0.21 9.42,-1.24 12.21,-3.31 a 10,10 0 0 0 4,-8.33 19.62,19.62 0 0 0 -0.7,-4.87 c 11.49,-0.08 20.43,-1.13 20.43,-14 0,-11.16 -9.73,-20.79 -19,-24 9.85,-30.6 9,-66.21 -1.72,-94.48 l -0.64,-0.41 a 99.8,99.8 0 0 0 29.93,-10.82 c 3.76,6 7.43,11.95 16.11,10.71 13.07,-1.87 18.58,-21.42 7.38,-32.92 a 47.18,47.18 0 0 0 5.74,-15.43 z"
fill="#ffffff"
stroke="#231f20"
stroke-width="8"
id="path16" />
<path
d="m 237.56773,127.68 c 5.43,-29.68 -19.96,-53.31 -58.57,-66.55 -10.4,-36.77 -33.92,-58.63 -68.33,-58.63 -19.999997,0 -37.739997,7.84 -49.139997,20 -25.6,1.6 -25.78,31.73 -48.13,74.81 -17.4899997,33.74 -3.7299997,68.69 38.48,74.11 -6.59,15.25 -10,32.92 -10.34,50.77 -21.41,-24.53 -15.54,-49.87 -27.54,-49.19 -14.9999997,0.83 4.19,54 30.81,83.64 a 133,133 0 0 0 3.98,14.36 c -9.29,3.21 -19,12.84 -19,24 0,12.7 8.7,13.88 20,14 a 20.85,20.85 0 0 0 -0.59,4.46 10.38,10.38 0 0 0 4,8.59 c 2.84,2.16 6.87,3.25 12.5,3.46 0.82,0 1.63,0 2.42,0 v 0 c 11.9,0 20.08,-3.33 25.25,-8 a 21.22,21.22 0 0 0 7.249997,-15.51 15.26,15.26 0 0 0 -0.42,-3.64 17.81,17.81 0 0 1 -0.349997,-2 168.68,168.68 0 0 1 28.879997,-0.18 c -0.14,1 -0.27,1.77 -0.38,2.21 a 14,14 0 0 0 -0.39,3.36 c 0,4.91 2.24,10.87 7.6,15.63 5.36,4.76 13.78,8.16 25.85,8.16 v 0 c 0.79,0 1.6,0 2.42,0 5.49,-0.21 9.42,-1.24 12.21,-3.31 a 10,10 0 0 0 4,-8.33 19.62,19.62 0 0 0 -0.7,-4.87 c 11.49,-0.08 20.43,-1.13 20.43,-14 0,-11.16 -9.73,-20.79 -19,-24 9.85,-30.6 9,-66.21 -1.72,-94.48 l -0.64,-0.41 a 99.8,99.8 0 0 0 29.93,-10.82 c 3.76,6 7.43,11.95 16.11,10.71 13.07,-1.87 18.58,-21.42 7.38,-32.92 a 47.18,47.18 0 0 0 5.74,-15.43 z"
fill="#ffffff"
stroke="#231f20"
stroke-width="5"
id="path17" />
<path
d="m 180.75773,271 c 4,-2 20,6 19,24 -1,18 -23,14 -23,14 l -10,-23 c 0,0 -4,-44 -3,-67 1,-23 -15,-39 -15,-39 a 125.8,125.8 0 0 1 16,-1 c 9,0 14.26,-2.48 14.26,-2.48 0,0 7.74,9.48 8.74,41.48 1,32 -10.98,55 -7,53 z"
fill="#a97f2c"
id="path18" />
<path
d="m 158.77773,23 c 9,9 21.79,40.45 21.79,40.45 0,0 -22.47,-2.28 -32.12,-11.37 -5.54,-5.24 -31.45,-47.96 -31.45,-47.96 8,0 32.78,9.88 41.78,18.88 z"
fill="#a97f2c"
id="path19" />
<path
d="m 110.66773,2.5 c 0,0 31,46.83 30.68,63.68 -0.5,24.7 -43.529997,18.92 -15.57,86.8 7,17 -9,31 -31.999997,27 -10.48,-1.82 -30,3 -30,34 0,31 -2,72 -2,72 l -9,23 c 0,0 -22,3 -22,-10 0,-13 6,-17 15,-24 9,-7 -0.94,-18.36 -0.94,-18.36 0,0 -31.06,-44.62 -32.06,-51.62 -1,-7 11,-16 11,-16 0,0 14.53,30.41 17.76,33.2 3.23,2.79 2.24,-39.2 8.24,-45.2 6,-6 9,-151 9,-151 0,0 4.79,-17 51.889997,-23.5 z"
fill="#a97f2c"
id="path20" />
<path
d="m 102.77773,127 c -40.339997,7.18 -60.439997,50.68 -61.239997,95.17 -21.41,-24.51 -15.54,-49.85 -27.54,-49.17 -14.9999997,0.83 4.19,54 30.81,83.64 a 133,133 0 0 0 3.98,14.36 c -9.29,3.21 -19,12.84 -19,24 0,13.81 10.29,14 23,14 a 22,22 0 0 0 15.84,-6.89 c 29.16,-8.11 61.159997,-9.11 92.309997,0 a 22,22 0 0 0 15.84,6.89 c 12.7,0 23,-0.19 23,-14 0,-11.16 -9.73,-20.79 -19,-24 9.85,-30.6 9,-66.21 -1.72,-94.48"
fill="none"
stroke="#231f20"
stroke-width="5"
id="path21" />
<path
d="m 64.777733,210 c 0,0 -1,65 -3,76 -2,11 -24,36 4,37 28,1 34,-16 32,-24 -2,-8 -4,-68 -4,-68"
fill="#ffffff"
id="path22" />
<path
d="m 68.107733,325.52 c -0.79,0 -1.6,0 -2.42,0 v 0 c -5.63,-0.21 -9.66,-1.3 -12.5,-3.46 v 0 a 10.38,10.38 0 0 1 -4,-8.59 v 0 c 0,-5.11 2.46,-10.42 4.84,-15.45 v 0 c 2.4,-5 4.86,-9.76 5.31,-12.45 v 0 c 0.45,-2.43 0.9,-8.61 1.27,-16.19 v 0 c 0.37,-7.61 0.69,-16.75 0.94,-25.56 v 0 c 0.49,-17.6 0.75,-12.84 0.75,-20.22 a 40.44,40.44 0 0 1 2.48,-13.6 c 0,0 2.49,5 2.49,13.65 0,6.32 -0.56,23 -1.69,46 v 0 c -0.38,7.69 -0.8,13.77 -1.35,16.84 v 0 c -0.78,4.1 -3.38,8.78 -5.72,13.71 v 0 c -2.36,4.86 -4.38,9.88 -4.34,13.29 v 0 a 5.35,5.35 0 0 0 2.06,4.63 v 0 c 1.54,1.2 4.56,2.25 9.63,2.42 v 0 c 0.77,0 1.51,0 2.25,0 v 0 c 11,0 17.84,-3 21.93,-6.73 v 0 a 16.26,16.26 0 0 0 5.59,-11.81 v 0 a 10.28,10.28 0 0 0 -0.28,-2.43 v 0 c -0.6,-2.46 -1,-7.6 -1.54,-14.43 v 0 c -0.47,-6.78 -0.91,-15 -1.28,-23 v 0 c -0.75,-16 -0.54,-12.3 -0.54,-18.79 a 47.53,47.53 0 0 1 1.79,-12.35 37.86,37.86 0 0 1 3.22,14 c 0,7.12 -0.44,-5.66 0,5.3 v 0 c 0.46,11 1.09,24.45 1.79,34.53 v 0 a 119.68,119.68 0 0 0 1.399997,13.56 v 0 a 15.26,15.26 0 0 1 0.42,3.64 v 0 a 21.22,21.22 0 0 1 -7.209997,15.48 v 0 c -5.17,4.7 -13.35,8 -25.25,8 v 0 z"
fill="#231f20"
id="path23" />
<path
d="m 163.77773,210 c 0,0 1,65 3,76 2,11 25,36 -3,37 -28,1 -35,-16 -33,-24 2,-8 4,-68 4,-68"
fill="#ffffff"
id="path24" />
<path
d="m 135.55773,317.36 c -5.36,-4.76 -7.6,-10.72 -7.6,-15.63 v 0 a 14,14 0 0 1 0.39,-3.36 v 0 a 119.68,119.68 0 0 0 1.4,-13.56 v 0 c 0.47,-6.72 0.9,-15 1.28,-22.95 v 0 c 0.75,-16 1.25,-13.46 1.25,-19.34 0,-5.88 3.06,-11.62 3.06,-11.62 a 38.48,38.48 0 0 1 1.93,11.79 c 0,6.46 -1.12,22.13 -2.53,42.46 v 0 c -0.49,6.83 -0.94,12 -1.54,14.44 v 0 a 8.92,8.92 0 0 0 -0.25,2.14 v 0 a 16.46,16.46 0 0 0 5.93,11.89 v 0 c 4.31,3.81 11.38,6.89 22.56,6.9 v 0 c 0.73,0 1.48,0 2.24,0 v 0 c 4.95,-0.16 7.9,-1.17 9.4,-2.31 v 0 a 4.88,4.88 0 0 0 2,-4.33 v 0 c 0.06,-3.36 -2.11,-8.47 -4.65,-13.42 v 0 c -2.5,-5 -5.27,-9.79 -6.09,-14 v 0 c -0.54,-3.07 -1,-9.15 -1.35,-16.84 v 0 c -0.37,-7.67 -0.68,-16.84 -0.93,-25.67 v 0 c -0.51,-17.64 -0.75,-19.58 -0.75,-25.83 a 96.35,96.35 0 0 1 0.95,-12.54 c 0,0 4.05,7.12 4.05,12.54 0,5.42 0.13,1 0.42,13 v 0 c 0.28,12 0.7,26.85 1.26,38.27 v 0 c 0.37,7.59 0.82,13.76 1.27,16.19 v 0 c 0.45,2.7 3.06,7.59 5.64,12.64 v 0 c 2.54,5.12 5.13,10.49 5.18,15.67 v 0 a 10,10 0 0 1 -4,8.33 v 0 c -2.79,2.07 -6.72,3.1 -12.21,3.31 v 0 c -0.82,0 -1.63,0 -2.42,0 v 0 c -12.07,0 -20.48,-3.4 -25.85,-8.16 z"
fill="#231f20"
id="path25" />
<path
d="m 126.99773,176.07 c 54.32,10 103.81,-11.71 110.53,-48.39 5.47,-29.68 -19.92,-53.31 -58.53,-66.55 -10.4,-36.77 -33.92,-58.63 -68.33,-58.63 -34.409997,0 -62.289997,23.24 -62.289997,51.91"
fill="none"
stroke="#231f20"
stroke-width="5"
id="path26" />
<path
d="m 240.38773,99.78 c 1.66,9.76 -6.87,19.37 -19.07,21.45 -12.2,2.08 -23.44,-4.15 -25.1,-13.91 -1.66,-9.76 6.87,-19.32 19.07,-21.45 12.2,-2.13 23.43,4.13 25.1,13.91 z"
fill="#231f20"
stroke="#231f20"
stroke-width="4"
id="path27" />
<path
d="m 102.99773,96.77 c 21.86,57.92 -11.579997,75.41 -39.339997,75.41 -51.37,0 -69.3099997,-38.16 -50.27,-74.87 23,-44.26 22.5,-74.86 50.27,-74.86 27.77,0 24.77,35.63 39.339997,74.32 z"
fill="#a97f2c"
id="path28" />
<path
fill="none"
stroke="#000000"
stroke-width="5"
id="path29" />
<path
d="m 231.25773,89.15 c 0.94,2.48 -4.79,6.94 -12.8,10 -8.01,3.06 -15.25,3.49 -16.19,1 -0.94,-2.49 4.79,-6.94 12.8,-10 8.01,-3.06 15.25,-3.47 16.19,-1 z"
fill="#ffffff"
id="path30" />
<ellipse
cx="114.03773"
cy="57.59"
rx="11.72"
ry="7.98"
fill="#231f20"
stroke="#231f20"
stroke-width="4"
id="ellipse30" />
<path
d="m 176.54773,49.55 c 0,4.69 -2.67,8.48 -9.09,8.48 -6.42,0 -11.61,-3.79 -11.61,-8.48 0,-4.69 5.2,-8.48 11.61,-8.48 6.41,0 9.09,3.8 9.09,8.48 z"
fill="#231f20"
id="path31" />
<path
d="m 113.26773,54.05 c 0,1.65 -1.66,3 -3.7,3 -2.04,0 -3.71,-1.34 -3.71,-3 0,-1.66 1.66,-3 3.71,-3 2.05,0 3.7,1.35 3.7,3 z"
fill="#ffffff"
id="path32" />
<path
d="m 165.83773,47.42 a 3.18,3.18 0 1 1 -3.14,-2.71 3,3 0 0 1 3.14,2.71 z"
fill="#ffffff"
id="path33" />
<path
d="m 161.51773,167 c 33.07,10.23 74.23,-0.12 75.67,-41.74 0,0 0.8,-8.93 -1.41,-4.64 -10,19.33 -33.36,28.06 -70.46,32.76 -5.23,0.66 -16.39,0.75 -17.08,5.67 -0.37,2.66 3.03,4.81 13.28,7.95 z"
fill="#231f20"
id="path34" />
<path
d="m 226.90773,139.08 c 15.18,10.12 11.11,32.68 -2.75,35.46 -15.51,3.11 -16.06,-17.89 -29.19,-20.4 0,0 13.2,-2.74 20.33,-6.48 a 46.92,46.92 0 0 0 11.61,-8.58 z"
fill="#f26322"
stroke="#231f20"
stroke-width="5"
id="path35" />
<path
d="m 216.88773,149.3 c 0,0 10.78,5.91 11.83,20.83 0,0 -2.91,-8.95 -5.29,-12.12 z"
fill="#a74624"
id="path36" />
<path
d="m 100.87773,117.06 c 0,0 10.49,52.5 -53.999997,43.5 0,0 24,-12 33,-19.5 9,-7.5 20.999997,-24 20.999997,-24 z"
fill="#886327"
id="path37" />
<metadata
id="metadata38">
<rdf:RDF>
<cc:Work
rdf:about="">
<dc:title>beagleboard-logo</dc:title>
</cc:Work>
</rdf:RDF>
</metadata>
</svg>
<!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 1.1//EN" "http://www.w3.org/Graphics/SVG/1.1/DTD/svg11.dtd">
<svg width="549" height="442" viewBox="0 0 549 442" version="1.1" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" xml:space="preserve" xmlns:serif="http://www.serif.com/" style="fill-rule:evenodd;clip-rule:evenodd;stroke-linejoin:round;stroke-miterlimit:2;">
NOTE: This file *must* embed its own webfont in order to render
correctly, due to the fact that we're rendering via an <img> tag and
<img> does not inherit webfonts from the enclosing context. The webfont
below has been subset to include only uppercase letters and numbers to
reduce size. If this template is updated in the future, make sure to
include the webfont and modify the <text> element's style below.
<defs>
<style>
@font-face {
font-family: 'DejaVu Sans Mono Subset';
src: url(data:application/font-woff2;charset=utf-8;base64,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) format('woff2');
font-weight: normal;
font-style: normal;
</style>
</defs>
<rect id="stacked-template" x="0" y="0" width="548.94" height="441.02" style="fill:none;"/>
<g id="stacked-template1" serif:id="stacked-template">
<g id="logo">
<g>
<path d="M46.942,85.472l-0,209.895l455.056,-0l0,-209.895l-18.106,0l-0.397,191.392l-418.05,-0l-0,-172.889l355.694,0l0,-18.503l-374.197,0Z" style="fill:rgb(51,51,51);fill-rule:nonzero;"/>
<path d="M153.705,192.668c0,-15.853 -1.638,-27.177 -4.915,-33.972c-3.228,-6.794 -8.553,-10.192 -15.973,-10.192c-7.372,0 -12.697,3.398 -15.974,10.192c-3.228,6.794 -4.842,18.117 -4.842,33.972c-0,15.804 1.614,27.104 4.842,33.898c3.277,6.794 8.601,10.191 15.974,10.191c7.42,-0 12.745,-3.373 15.973,-10.119c3.277,-6.794 4.915,-18.118 4.915,-33.972m15.251,0c0,18.793 -2.987,32.816 -8.962,42.067c-5.927,9.252 -14.986,13.878 -27.177,13.878c-12.191,-0 -21.25,-4.602 -27.177,-13.806c-5.926,-9.203 -8.89,-23.249 -8.89,-42.138c0,-18.84 2.964,-32.886 8.89,-42.138c5.975,-9.251 15.034,-13.877 27.177,-13.877c12.191,-0 21.25,4.626 27.177,13.877c5.975,9.252 8.962,23.298 8.962,42.138" style="fill:rgb(51,51,51);fill-rule:nonzero;"/>
<path d="M250.508,142.308l0,14.817c-4.433,-2.843 -8.89,-4.987 -13.371,-6.433c-4.433,-1.445 -8.914,-2.168 -13.444,-2.168c-6.891,0 -12.335,1.614 -16.335,4.843c-3.999,3.18 -5.999,7.493 -5.999,12.937c0,4.771 1.301,8.409 3.903,10.915c2.65,2.505 7.565,4.601 14.745,6.288l7.661,1.735c10.119,2.361 17.491,6.071 22.117,11.131c4.626,5.059 6.939,11.95 6.939,20.671c0,10.264 -3.18,18.094 -9.541,23.491c-6.36,5.396 -15.612,8.095 -27.755,8.095c-5.059,-0 -10.143,-0.554 -15.25,-1.663c-5.108,-1.06 -10.24,-2.674 -15.396,-4.842l0,-15.54c5.542,3.517 10.77,6.095 15.685,7.733c4.963,1.639 9.95,2.458 14.961,2.458c7.373,-0 13.107,-1.638 17.203,-4.915c4.095,-3.325 6.143,-7.951 6.143,-13.878c0,-5.396 -1.421,-9.516 -4.264,-12.359c-2.795,-2.843 -7.686,-5.035 -14.673,-6.577l-7.805,-1.807c-10.023,-2.265 -17.299,-5.686 -21.828,-10.264c-4.53,-4.578 -6.795,-10.721 -6.795,-18.431c0,-9.637 3.229,-17.347 9.686,-23.129c6.505,-5.83 15.13,-8.746 25.875,-8.746c4.144,0.001 8.505,0.482 13.083,1.446c4.577,0.916 9.396,2.313 14.455,4.192" style="fill:rgb(51,51,51);fill-rule:nonzero;"/>
<path d="M276.29,138.607l14.672,0l-0,44.235l39.97,0l0,-44.235l14.673,0l-0,107.911l-14.673,0l0,-51.389l-39.97,-0l-0,51.389l-14.672,0l-0,-107.911" style="fill:rgb(51,51,51);fill-rule:nonzero;"/>
</g>
<path d="M355.453,138.607l14.238,0l10.336,87.601l12.288,-57.968l15.25,0l12.432,58.113l35.008,-167.926l14.239,-0l-40.79,188.091l-13.805,0l-14.673,-64.11l-14.6,64.11l-13.806,0l-16.118,-107.911" style="fill:rgb(255,68,68);fill-rule:nonzero;"/>
</g>
<text id="project-uid" x="56.375px" y="381.312px" style="font-family: 'DejaVu Sans Mono', 'DejaVuSansMono', 'DejaVu Sans Mono Subset';font-size:90.49px;fill:rgb(51,51,51);">US002120</text>
</g>
</svg>
<defs>
<style>
@font-face {
font-style: normal;
</style>
</defs>
<g id="logo">
<g>
</g>
</g>
<text id="project-uid" x="56.375px" y="381.312px" style="font-family: 'DejaVu Sans Mono', 'DejaVuSansMono', 'DejaVu Sans Mono Subset';font-size:90.49px;fill:rgb(51,51,51);">US000169</text>
</g>
</svg>
<defs>
<style>
@font-face {
font-style: normal;
</style>
</defs>
<g id="logo">
<g>
</g>
</g>
<text id="project-uid" x="56.375px" y="381.312px" style="font-family: 'DejaVu Sans Mono', 'DejaVuSansMono', 'DejaVu Sans Mono Subset';font-size:90.49px;fill:rgb(51,51,51);">US000011</text>
</g>
</svg>
<defs>
<style>
@font-face {
font-style: normal;
</style>
</defs>
<g id="logo">
<g>
</g>
</g>
<text id="project-uid" x="56.375px" y="381.312px" style="font-family: 'DejaVu Sans Mono', 'DejaVuSansMono', 'DejaVu Sans Mono Subset';font-size:90.49px;fill:rgb(51,51,51);">US000236</text>
</g>
</svg>
<defs>
<style>
@font-face {
font-style: normal;
</style>
</defs>
<g id="logo">
<g>
</g>
</g>
<text id="project-uid" x="56.375px" y="381.312px" style="font-family: 'DejaVu Sans Mono', 'DejaVuSansMono', 'DejaVu Sans Mono Subset';font-size:90.49px;fill:rgb(51,51,51);">US000064</text>
</g>
</svg>
<defs>
<style>
@font-face {
font-style: normal;
</style>
</defs>
<g id="logo">
<g>
</g>
</g>
<text id="project-uid" x="56.375px" y="381.312px" style="font-family: 'DejaVu Sans Mono', 'DejaVuSansMono', 'DejaVu Sans Mono Subset';font-size:90.49px;fill:rgb(51,51,51);">US002175</text>
</g>
</svg>
