  • docs/docs.beagleboard.io
  • jkridner/docs
  • lorforlinux/docs.beagleboard.io
  • harshilbhatt2001/docs.beagleboard.io
  • Krishna_13/docs.beagleboard.io
  • gpioblink/docs.beagleboard.io
  • dhruvag2000/docs.beagleboard.io
  • jiande/docs.beagleboard.io
  • beagleplay/docs
  • beaglev-ahead/docs
  • sabeeh.khan14/docs.beagleboard.io
  • yoder/docs.beagleboard.io
  • jdneal/docs.beagleboard.io
  • ayush1325/docs.beagleboard.io
  • vishnumaiea/docs.beagleboard.io
  • andrei1998/docs-beagleboard-io-zephyr-demo
  • andrei1998/docs.beagleboard.io
  • nmenon/docs.beagleboard.io
  • epenguin/docs.beagleboard.io
  • paul_buxton/docs.beagleboard.io
  • anujdeshpande/docs.beagleboard.io
  • melta101/docs.beagleboard.io
  • krvprashanth/docs.beagleboard.io
  • samdai/docs.beagleboard.io
  • bustedwing1/docs.beagleboard.io
  • cshegedus/docs.beagleboard.io
  • wmat/docs.beagleboard.io
  • Roger18/docs.beagleboard.io
  • himanshuk/docs.beagleboard.io
  • vvaishak/docs.beagleboard.io
  • alecdenny/docs.beagleboard.io
  • san.s.kar03/docs.beagleboard.io
  • andrei1998/docs-beagleboard-io-fixes
  • SomeInterestingUserName/docs.beagleboard.io
  • edge-ai/docs
  • andrei1998/docs-beagleboard-io-rtc
  • devarsht/docs.beagleboard.io
  • andrei1998/docs-beagleboard-io-deepak-fork
  • superchamp234/docs.beagleboard.io
  • lranders/docs.beagleboard.io
  • kushalkr/docs.beagleboard.io
  • mkorpershoek/docs.beagleboard.io
  • prajnark/docs.beagleboard.io
  • touchhowling/docs.beagleboard.io
  • RobertCNelson/docs.beagleboard.io
  • Shankari02/docs.beagleboard.io
  • LucienMorey/docs.beagleboard.io
  • ketanthorat/docs.beagleboard.io
  • jjateen/docs.beagleboard.io
  • Whiz-Manas/mana-docs-beagleboard-io
  • beagley-ai/zephyr/docs.beagleboard.io
  • giuliomoro/docs.beagleboard.io
52 results
with 4048 additions and 4747 deletions
BeagleBoard .. _beagleboard-boards-home:
BeagleBoard (all)
BeagleBoard boards are low-cost, ARM-based development boards suitable for rapid prototyping and BeagleBoard.org single board computers (SBCs) and microcontroller development boards are fully open-source, low-cost, RISC-V & ARM
open-hardware to enable professionals to develop production systems. based boards. Which makes them suitable for students to learn about embedded electronics & embedded Linux. Beagle development
platforms also enable rapid prototyping for professionals to develop industrial & production systems.
.. note::
Make sure to read and accept all the terms & condition provided in the :ref:`boards-terms-and-conditions` page.
Use of either the boards or the design materials constitutes agreement to the T&C including any
modifications done to the hardware or software solutions provided by beagleboard.org foundation.
The latest unified docs PDF is linked below.
* `BeagleBoard.org unified docs PDF <https://docs.beagleboard.org/latest/beagleboard-docs.pdf>`_
The latest PDF-formatted System Reference Manual for each BeagleBoard board is linked below. The latest System Reference Manual (PDF) for older BeagleBoard boards are linked below.
* `BeagleBoard <https://git.beagleboard.org/beagleboard/beagleboard/-/blob/master/BeagleBoard_revC5_SRM.pdf>`_ * `BeagleBoard <https://git.beagleboard.org/beagleboard/beagleboard/-/blob/master/BeagleBoard_revC5_SRM.pdf>`_
* `BeagleBoard-xM <https://git.beagleboard.org/beagleboard/beagleboard-xm/-/blob/master/BeagleBoard-xM_SRM.pdf>`_ * `BeagleBoard-xM <https://git.beagleboard.org/beagleboard/beagleboard-xm/-/blob/master/BeagleBoard-xM_SRM.pdf>`_
This diff is collapsed.
.. _bbai64-quick-start:
Quick Start Guide
This section provides instructions on how to hook up your board. This Beagle requires a 5V > 3A (15W)
power supply to work properly via either USB Type-C power adapter or a barrel jack power adapter.
Recommended adapters can be found at :ref:`accessories-power-supplies` section. All the
:ref:`BeagleBone AI-64 connections ports` we will use in this chapter are shown in the figure below.
.. _BeagleBone AI-64 connections ports:
.. figure:: images/ch03/ports.*
:width: 740px
:align: center
.. _whats-in-the-box:
What’s In the Box
In the box you will find two main items as shown in :ref:`bbai-64-pacakage`.
* `BeagleBone AI-64 <https://www.beagleboard.org/boards/beaglebone-ai-64>`_
* Instruction card
.. note:: A USB-C to USB-C cable is not included, but recommended for the tethered scenario and creates
a developer experience where the board can be used immediately with no other equipment needed.
.. tip:: For board files, 3D model, and more, you can checkout `BeagleBona AI-64 repository on OpenBeagle <https://openbeagle.org/beagleboard/beaglebone-ai-64>`_.
.. _bbai-64-pacakage:
.. figure:: images/ch03/bbai64-in-box.*
:width: 740px
:align: center
BeagleBone AI-64 box content
Methods of operation
1. Tethered to a PC
2. Standalone development platform in a PC configuration using external peripherals
.. _main-connection-scenarios:
Main Connection Scenarios
This section describes how to connect and power the board and serves as a slightly more detailed
description of the Quick Start Guide included in the box. The board can be configured in several
different ways, but we will discuss the two most common scenarios.
* Tethered to a PC via the USB cable
* ``Board is accessed as a storage drive and virtual Ethernet connection.``
* Standalone Desktop
* ``Display``
* ``Keyboard and Mouse``
* ``External 5V > 3A power supply``
Each of these configurations is discussed in general terms in the following sections.
.. tab-set::
.. tab-item:: Tethered To A PC
In this configuration, the board is powered by the PC via a single USB cable. The board is accessed either as a USB storage drive or via the browser on the connected PC. You need to use either Firefox or Chrome on the PC, Internet Explorer will not work properly.
.. figure:: images/ch03/usb-tethering.*
:width: 740px
:align: center
Tethered Configuration
At least 5V @ 3A is required to power the board, In most cases the PC may not be able to supply
sufficient power for the board unless the connection is made over a Type-C to Type-C cable. You
should always use an external 5V > 3A DC power supply connected to the barrel jack if you are
unsure that the system can provide the required power or are otherwise using a USB-A to Type-C
cable which will always require power from the DC barrel jack.
**Connect the Cable to the Board**
1. Connect the type C USB cable to the board as shown in the figure below. The connector is on the top side of the board near barrel jack.
.. figure:: images/ch03/usb-c-connection.*
:width: 740px
:align: center
USB Connection to the Board
2. Connect the USB-A end of the cable to your PC or laptop USB port as shown in the figure below.
.. figure:: images/ch03/usb-a-connection.*
:width: 740px
:align: center
USB Connection to the PC/Laptop
3. The board will power on and the power LED will be on as shown in the figure below.
.. figure:: images/ch03/power-led.*
:width: 740px
:align: center
Board Power LED
4. When the board starts to the booting process started by the process of applying power, the LEDs will come on in sequence as shown in the figure below. It will take a few seconds for the status LEDs to come on, so be patient. The LEDs will be flashing in an erratic manner as it begins to boot the Linux kernel.
.. figure:: images/ch03/led-pattern.*
:width: 740px
:align: center
Board Boot Status
**Accessing the Board as a Storage Drive**
The board will appear around a USB Storage drive on your PC after thekernel has booted, which will take a round 10 seconds. The kernel on the board needs to boot before the port gets enumerated. Once the board appears as a storage drive, do the following:
1. Open the USB Drive folder.
2. Click on the file named **start.htm**
3. The file will be opened by your browser on the PC and you should get a display showing the Quick Start Guide.
4. Your board is now operational! Follow the instructions on your PC screen.
.. tab-item:: Standalone w/Display and Keyboard/Mouse
In this configuration, the board works more like a PC, totally free from any connection to a PC as shown in the figure below. It allows you to create your code to make the board do whatever you need it to do. It will however require certain common PC accessories. These accessories and instructions are described in the following section.
.. figure:: images/ch03/desktop-configuration.*
:width: 740px
:align: center
Desktop Configuration
Ethernet cable and M.2 WiFi + Bluetooth card are optional. They can be used if network access required.
**Required Accessories**
In order to use the board in this configuration, you will need the following accessories:
* :ref:`5V > 3A power supply <accessories-power-supplies>`.
* :ref:`Display Port or HDMI monitor <accessories-displays>`.
* :ref:`miniDP-DP or active miniDP-HDMI cable <accessories-cables_minidp_hdmi>`.
* :ref:`USB wired/wireless keyboard and mouse <accessories-peripherals>`.
**Optional Accessories**
* Powered USB hub, The board has only two USB Type-A host ports, so you may need to use a powered USB Hub if you wish to add additional USB devices, such as a USB WiFi adapter.
* M.2 Bluetooth & WiFi module, For wireless connections, a USB WiFi adapter or a recommended M.2 WiFi module can provide wireless networking.
**Connecting Up the Board**
1. Connect the miniDP to DP or active miniDP to HDMI cable from your BeagleBone AI-64 to your monitor.
.. figure:: images/ch03/monitor-cable.*
:width: 740px
:align: center
Connect miniDP-DP or active miniDP-HDMI cable to BeagleBone AI-64
1. If you have an Display Port or HDMI monitor with HDMI-HDMI or DP-DP cable you can use adapters as shown in the figure below.
.. figure:: images/ch03/display-adapters.*
:width: 740px
:align: center
Display adapters
1. If you have wired/wireless USB keyboard and mouse such as seen in the figure below, you need to plug the receiver in the USB host port of the board as shown in the figure below.
.. figure:: images/ch03/mouse-keyboard.*
:width: 740px
:align: center
Keyboard and Mouse
1. Connect the Ethernet Cable
If you decide you want to connect to your local area network, an Ethernet cable can be used.
Connect the Ethernet Cable to the Ethernet port as shown in the figure below. Any
standard 100M Ethernet cable should work.
.. figure:: images/ch03/ethernet-cable.*
:width: 740px
:align: center
Ethernet Cable Connection
1. The final step is to plug in the DC power supply to the DC power jack as shown in the figure below.
.. figure:: images/ch03/barrel-jack.*
:width: 740px
:align: center
External DC Power
1. The cable needed to connect to your display is a miniDP-DP or active miniDP-HDMI. Connect the miniDP connector end to the board at this time. The connector is on the top side of the board as shown in the figure below.
.. figure:: images/ch03/miniDP-connector.*
:width: 740px
:align: center
Connect miniDP to DP or active miniDP to HDMI Cable to the Board
The connector is fairly robust, but we suggest that you not use the cable as a leash for your Beagle. Take proper care not to put too much stress on the connector or cable.
1. Booting the Board
As soon as the power is applied to the board, it will start the booting up process. When the board starts to boot the LEDs will come on. It will take a few seconds for the status LEDs to come on, so be patient. The LEDs will be flashing in an erratic manner as it boots the Linux kernel.
.. figure:: images/ch03/leds.*
:width: 740px
:align: center
BeagleBone AI-64 LEDs
While the four user LEDS can be over written and used as desired, they do have specific
meanings in the image that is shipped with the board once the Linux kernel has booted.
* **USR0** is the heartbeat indicator from the Linux kernel.
* **USR1** turns on when the microSD card is being accessed
* **USR2** is an activity indicator. It turns on when the kernel is not in the idle loop.
* **USR3** turns on when the onboard eMMC is being accessed.
* **USR4** is an activity indicator for WiFi.
1. A Booted System
a. The board will have a mouse pointer appear on the screen as it enters the Linux boot step. You may have to move the physical mouse to get the mouse pointer to appear. The system can come up in the suspend mode with the monitor in a sleep mode.
b. After a minute or two a login screen will appear. You do not have to do anything at this point.
c. After a minute or two the desktop will appear. It should be similar to the one shown in the figure below. HOWEVER, it will change from one release to the next, so do not expect your system to look exactly like the one in the figure, but it will be very similar.
d. And at this point you are ready to go! The figure below shows the desktop after booting.
.. figure:: images/ch03/xfce-desktop.*
:width: 740px
:align: center
BeagleBone XFCE Desktop Screen
.. _bbai64-update:
Update software
Production boards currently ship with the factory-installed 2022-01-14-8GB image. To upgrade
from the software image on your BeagleBone AI-64 to the latest, you don't need to completely
reflash the board. If you do want to reflash it, visit the flashing instructions on the getting
started page. Factory Image update (without reflashing)…
.. code-block:: bash
sudo apt update
sudo apt install --only-upgrade bb-j721e-evm-firmware generic-sys-mods
sudo apt upgrade
Update U-Boot:
to ensure only tiboot3.bin is in boot0, the pre-production image we tried to do more in boot0, but failed…
sudo /opt/u-boot/bb-u-boot-beagleboneai64/install-emmc.sh
sudo /opt/u-boot/bb-u-boot-beagleboneai64/install-microsd.sh
sudo reboot
Update Kernel and SGX modules:
sudo apt install bbb.io-kernel-5.10-ti-k3-j721e
Update xfce:
sudo apt install bbb.io-xfce4-desktop
Update ti-edge-ai 8.2 examples
sudo apt install ti-edgeai-8.2-base ti-vision-apps-8.2 ti-vision-apps-eaik-firmware-8.2
Cleanup:
sudo apt autoremove --purge
Next steps
* :ref:`ai_64_edgeai_home`
.. _bbai64-demos-and-tutorials:
Demos and Tutorials
.. toctree::
:maxdepth: 1
:hidden:
edge_ai_apps/index
.. _bbai64-support:
Additional Support Information
All support for this design is through BeagleBoard.org community
at `BeagleBoard.org forum <https://forum.beagleboard.org/tag/bbai64>`_.
.. _bbai64-certifications:
Certifications and export control
Export designations
* HS: 8471504090
* US HS: 8543708800
* EU HS: 8471707000
.. _hardware-design:
Hardware Design
You can find all BeagleBone AI-64 hardware files `here <https://git.beagleboard.org/beagleboard/beaglebone-ai-64>`_ under the `hw` folder.
Production board boot media
- `BeagleBone AI-64 Rev B1`_
.. _software-updates:
Software Updates
Follow instructions below to download the latest image for your BeagleBone AI-64:
1. Go to `BeagleBoard.org distro <https://www.beagleboard.org/distros>`_ page.
2. :ref:`filter-software-distribution-AI-64` from dropdown and download the image.
.. _filter-software-distribution-AI-64:
.. figure:: images/ch11/distros.*
:align: center
:alt: Filter Software Distributions for BeagleBone AI-64
.. tip::
You can follow the :ref:`flash-latest-image` guide for more information on
flashing the downloaded image to your board.
To see what SW revision is loaded into the eMMC check `/etc/dogtag`.
It should look something like as shown below,
.. code-block:: shell
root@BeagleBone:~# cat /etc/dogtag
BeagleBoard.org Debian Bullseye Xfce Image 2022-01-14
.. _rma-support:
RMA Support
If you feel your board is defective or has issues, request an Return Merchandise Application (RMA) by filling out the form at http://beagleboard.org/support/rma . You will need the serial number and revision of the board. The serial numbers and revisions keep moving. Different boards can have different locations depending on when they were made. The following figures show the three locations of the serial and revision number.
.. _trouble-shooting-video-output-issues:
Troubleshooting video output issues
.. warning::
When connecting to an HDMI monitor, make sure your miniDP adapter is *active*. A *passive* adapter will not work.
See :ref:`accessories-cables_minidp_hdmi` accessories section for tested cables list.
.. _getting-help:
Getting Help
If you need some up to date troubleshooting techniques, you can post your
queries on link: `BeagleBoard.org forum <https://forum.beagleboard.org/tag/bbai64>`_
.. _bbai64-Change-history:
Change History
This section describes the change history of this document and board. Document changes are not always a result of a board change. A board change will always result in a document change.
.. _bbai64-document-change-history:
Document Change History
This table seeks to keep track of major revision cycles in the documentation. Moving forward, we'll seek to align these version numbers across all of the various documentation.
.. _change-history-table, Change History:
.. list-table:: Table 1: Change History
:header-rows: 1
* - Rev
- Changes
- Date
- By
* - 0.0.1
- AI-64 initial prototype
- September 2021
- James Anderson
* - 0.0.2
- AI-64 final prototype
- December 2021
- James Anderson
* - 0.0.3
- AI-64 initial production release
- June 9, 2022
- Deepak Khatri and Jason Kridner
.. _board-changes:
Board Changes
Be sure to check the board revision history in the schematic file in the `BeagleBone AI-64 git repository <https://git.beagleboard.org/beagleboard/beaglebone-ai-64>`_ . Also check the `issues list <https://git.beagleboard.org/beagleboard/beaglebone-ai-64/-/issues>`_ .
.. _rev-B:
Rev B
We are starting with revision B based on this being an update to the BeagleBone Black AI. However, because this board ended up being so different, we've decided to name it BeagleBone AI-64, rather than simply a new revision. This refers to the Seeed release on 21 Dec 2021 of "BeagleBone AI-64_SCH_Rev B_211221". This is the initial production release.
.. _BeagleBone-AI-64-Mechanical:
Mechanical Details
.. _dimensions-and-weight:
Dimensions and Weight
.. table:: Dimensions & weight
| Parameter | Value |
| Size | 104 * 83* 37 mm |
| Max heigh | 23 mm |
| PCB Size | 102.5*80*2.0 mm |
| PCB Layers | 14 layers |
| PCB Thickness | 2.0 mm |
| RoHS compliant | Yes |
| Gross Weight | 249g |
| Net Weight | 193g |
.. _silkscreen-and-component-locations:
Silkscreen and Component Locations
.. figure:: images/hardware-design/board-dimensions.*
:width: 400px
:align: center
:alt: Board Dimensions
Board Dimensions
.. figure:: images/hardware-design/top-silkscreen.*
:width: 400px
:align: center
:alt: Top silkscreen
Top silkscreen
.. figure:: images/hardware-design/bottom-silkscreen.*
:width: 400px
:align: center
:alt: Bottom silkscreen
Bottom silkscreen
.. _bbai64-pictures:
Pictures
.. figure:: images/ch10/front.*
:width: 400px
:align: center
:alt: BeagleBone AI-64 front
.. figure:: images/ch10/back.*
:width: 400px
:align: center
:alt: BeagleBone AI-64 back
.. figure:: images/ch10/back-heatsink.*
:width: 400px
:align: center
:alt: BeagleBone AI-64 back with heatsink
.. figure:: images/bbai64-45-front.*
:width: 400px
:align: center
:alt: BeagleBone AI-64 front at 45° angle
.. figure:: images/ch10/45-back.*
:width: 400px
:align: center
:alt: BeagleBone AI-64 back at 45° angle
.. figure:: images/ch10/45-back-heatsink.*
:width: 400px
:align: center
:alt: BeagleBone AI-64 back with heatsink at 45° angle
.. figure:: images/ch10/feature.*
:width: 400px
:align: center
:alt: BeagleBone AI-64 ports
File added
Introduction
This document is the *System Reference Manual* for BeagleBone AI-64
and covers its use and design. The board will primarily be referred to
in the remainder of this document simply as the board, although it may
also be referred to as AI-64 or BeagleBone AI-64 as a reminder.
This design is subject to change without notice as we will work to keep
improving the design as the product matures based on feedback and
experience. Software updates will be frequent and will be independent of
the hardware revisions and as such not result in a change in the
revision number.
Make sure you frequently check the `BeagleBone AI-64 git repository <https://git.beagleboard.org/beagleboard/beaglebone-ai-64/>`_ for the most up to date support documents.
.. _Change-history:
Change History
.. _document-change-history:
:header-rows: 1
* - Rev
- Changes
- Date
- By
* - 0.0.1
- September 2021
- James Anderson
* - 0.0.2
- December 2021
- James Anderson
* - 0.0.3
- June 9, 2022
.. _board-changes:
Board Changes
.. _rev-B:
Rev B
.. _connecting-up-your-beaglebone-ai-64:
Connecting up your BeagleBone AI-64
This section provides instructions on how to hook up your board. This beagle requires a 5V > 3A power supply to work properly via either USB Type-C power adapter or a barrel jack power adapter.
Recommended adapters:
* 5V @ 3A `USB C power supply <https://www.digikey.com/en/products/detail/raspberry-pi/RPI-USB-C-power-supply-White-US/10258760>`_ adaptor for SBCs.
* 5V > 3A laptop/mobile adaptor with USB-C cable.
All the :ref:`BeagleBone AI-64 connections ports` we will use in this chapter are shown in the figure below.
.. figure:: images/ch03/ports.jpg
:width: 400px
:align: center
:alt: BeagleBone AI-64 connections ports
Fig 3.1 BeagleBone AI-64 connections ports
1. Tethered to a PC, or
2. As a standalone development platform in a desktop PC configuration with a Display Port Monitor, power supply, keyboard, and mouse
What’s In the Box
In the box you will find three main items as shown in :ref:`bbai-64-pacakage`.
* BeagleBone AI-64.
* Instruction card.
Get yourself a USB-A to USB-C and you have a setup for the tethered scenario and creates an out of box experience where the board can be used immediately with no other equipment needed.
.. figure:: images/ch03/bbai64-in-box.jpg
:width: 400px
:align: center
:alt: BeagleBone AI-64 box content
Fig: BeagleBone AI-64 box content
This section will describe how to connect the board for use. This section is basically a slightly more detailed description of the Quick Start Guide that came in the box. There is also a Quick Start Guide document on the board that should also be referred to. The intent here is that someone looking to purchase the board will be able to read this section and get a good idea as to what the initial set up will be like.
The board can be configured in several different ways, but we will discuss the two most common scenarios as described in the Quick Start Guide card that comes in the box.
* ``Board is accessed as a storage drive and``
* ``a virtual Ethernet connection.``
* Standalone desktop
* ``Display``
* ``Keyboard and mouse``
.. _tethered-to-a-pc:
Tethered To A PC
In this configuration, the board is powered by the PC via the provided USB cable --no other cables are required. The board is accessed either as a USB storage drive or via the browser on the PC. You need to use either Firefox or Chrome on the PC, Internet Explorer will not work properly. :ref:`tethered-figure` shows this configuration.
.. _tethered-figure:
.. figure:: images/ch03/usb-tethering.jpg
:width: 400px
:align: center
:alt: Tethered Configuration
Fig: Tethered Configuration
At least 5V @ 3A is required to power the board, In most cases the PC may not be able to supply sufficient power for the board. You should always use an external 5V > 3A DC power supply connected to the barrel jack.
.. _connect-the-cable-to-the-board:
1. Connect the type C USB cable to the board as shown in :ref:`usb-c-connect-figure`. The connector is on the top side of the board near barrel jack.
.. _usb-c-connect-figure:
.. figure:: images/ch03/usb-c-connection.jpg
:width: 400px
:align: center
:alt: USB Connection to the Board
Fig: USB Connection to the Board
2. Connect the USB-A end of thecable tp your PC or laptop USB port as shown in the :ref:`usb-a-connect-figure` below.
.. _usb-a-connect-figure,USB Connection to the PC/Laptop figure:
.. figure:: images/ch03/usb-a-connection.jpg
:width: 400px
:align: center
:alt: USB Connection to the PC/Laptop
Fig: USB Connection to the PC/Laptop
3. The board will power on and the power LED will be on as shown in :ref:`power-led-figure` below.
.. _power-led-figure:
.. figure:: images/ch03/power-led.jpg
:width: 400px
:align: center
:alt: Board Power LED
Fig: Board Power LED
4. When the board starts to the booting process started by the process of applying power, the LEDs will come on in sequence as shown in :ref:`boot-status-figure` below. It will take a few seconds for the status LEDs to come on, so be patient. The LEDs will be flashing in an erratic manner as it begins to boot the Linux kernel.
.. _boot-status-figure,Board Boot Status figure:
.. figure:: images/ch03/led-pattern.jpg
:width: 400px
:align: center
:alt: Board Boot Status
Fig: Board Boot Status
.. _accessing-the-board-as-a-storage-drive:
.. _standalone-wdisplay-and-keyboardmouse:
In this configuration, the board works more like a PC, totally free from any connection to a PC as shown in :ref:`desktop-config-figure`. It allows you to create your code to make the board do whatever you need it to do. It will however require certain common PC accessories. These accessories and instructions are described in the following section.
.. _desktop-config-figure,Desktop Configuration figure:
.. figure:: images/ch03/desktop-configuration.jpg
:width: 400px
:align: center
:alt: Desktop Configuration
Fig: Desktop Configuration
.. _required-accessories:
* 5V > 3A power supply.
* Display Port or HDMI monitor.
* miniDP-DP or active miniDP-HDMI cable (or a recommended **miniDP-DP or active miniDP-HDMI adapter** https://www.amazon.com/dp/B089GF8M87 has been tested and worked beautifully).
* USB wired/wireless keyboard and mouse.
* powered USB HUB (OPTIONAL). The board has only two USB Type-A host ports, so you may need to use a powered USB Hub if you wish to add additional USB devices, such as a USB WiFi adapter.
* M.2 Bluetooth & WiFi module (OPTIONAL). For wireless connections, a USB WiFi adapter or a recommended M.2 WiFi module can provide wireless networking.
.. _connecting-up-the-board:
.. _display-cable-figure,miniDP-DP or active miniDP-HDMI cable connection figure:
.. figure:: images/ch03/monitor-cable.jpg
:width: 400px
:align: center
:alt: Connect miniDP-DP or active miniDP-HDMI cable to BeagleBone AI-64
Fig: Connect miniDP-DP or active miniDP-HDMI cable to BeagleBone AI-64
2. If you have an Display Port or HDMI monitor with HDMI-HDMI or DP-DP cable you can use adapters as shown in. :ref:`display-adaptors-figure`.
.. _display-adaptors-figure:
.. figure:: images/ch03/display-adaptors.jpg
:width: 400px
:align: center
:alt: Display adaptors
Fig: Display adaptors
3. If you have wired/wireless USB keyboard and mouse such as
seen in :ref:`keyboard-mouse-figure` below, you need to plug the receiver in the USB host port of the board as shown in :ref:`keyboard-mouse-figure`.
.. _keyboard-mouse-figure:
.. figure:: images/ch03/mouse-keyboard.jpg
:width: 400px
:align: center
:alt: Keyboard and Mouse
FigKeyboard and Mouse
4. Connect the Ethernet Cable
If you decide you want to connect to your local area network, an Ethernet cable can be used. Connect the Ethernet Cable to the Ethernet port as shown in :ref:`ethernet-cable-figure`. Any standard 100M Ethernet cable should work.
.. _ethernet-cable-figure:
.. figure:: images/ch03/ethernet-cable.jpg
:width: 400px
:align: center
:alt: Ethernet Cable Connection
Fig: Ethernet Cable Connection
5. The final step is to plug in the DC power supply to the DC power jack as shown in :ref:`barrel-jack-figure` below.
.. _barrel-jack-figure,External DC Power figure:
.. figure:: images/ch03/barrel-jack.jpg
:width: 400px
:align: center
:alt: External DC Power
Fig: External DC Power
6. The cable needed to connect to your display is a miniDP-DP or active miniDP-HDMI. Connect the miniDP connector end to the board at this time. The connector is on the top side of the board as shown in :ref:`miniDP-figure` below.
.. _miniDP-figure,miniDP to DP or active miniDP to HDMI connection figure:
.. figure:: images/ch03/miniDP-connector.jpg
:width: 400px
:align: center
:alt: Connect miniDP to DP or active miniDP to HDMI Cable to the Board
Fig: Connect miniDP to DP or active miniDP to HDMI Cable to the Board
7. Booting the Board
.. _LEDs-figure,BeagleBone AI-64 LEDs figure:
.. figure:: images/ch03/leds.jpg
:width: 400px
:align: center
:alt: BeagleBone AI-64 LEDs
Fig: BeagleBone AI-64 LEDs
While the four user LEDS can be over written and used as desired, they do have specific meanings in the image that is shipped with the board once the Linux kernel has booted.
8. A Booted System
c. After a minute or two the desktop will appear. It should be similar to the one shown in :ref:`figure-16`. HOWEVER, it will change from one release to the next, so do not expect your system to look exactly like the one in the figure, but it will be very similar.
d. And at this point you are ready to go! :ref:`figure-16` shows the desktop after booting.
.. _figure-16:
.. figure:: images/ch03/xfce-desktop.jpg
:width: 400px
:align: center
:alt: BeagleBone XFCE Desktop Screen
Fig: BeagleBone XFCE Desktop Screen
.. _beaglebone-ai-64-overviewd:
BeagleBone AI-64 Overview
BeagleBone AI-64 is the latest addition to BeagleBoard.org family and like its predecessors, is designed to address the open-source Community, early adopters, and anyone interested in a low cost 64-bit Dual Arm® Cortex®-A72 processor based Single Board Computer (SBC).
It has been equipped with a minimum set of features to allow the user to
experience the power of the processor and is not intended as a full
development platform as many of the features and interfaces supplied by
the processor are not accessible from BeagleBone AI-64 via onboard
support of some interfaces. It is not a complete product designed to do
any particular function. It is a foundation for experimentation and
learning how to program the processor and to access the peripherals by
the creation of your own software and hardware.
It also offers access to many of the interfaces and allows for the use
of add-on boards called capes, to add many different combinations of
features. A user may also develop their own board or add their own
circuitry.
BeagleBone AI-64 is manufactured and warranted by partners listed at https://beagleboard.org/logo for the benefit of the community and its supporters including the current BeagleBoard.org Foundation board members
* Jason Kridner, principal of JK Embedded Consulting an independent contractor and architect for new Beagle designs.
* Drew Fustini, independent Linux developer
* Robert Nelson, applications engineer at Digi-Key
* Mark Yoder, professor at Rose-Hulman Institute of Technology
* Kathy Giori, product engineer at ZEDEDA
See `bbb.io/about <bbb.io/about>`_
BeagleBone AI-64 has been designed by Seeed Studio (Seeed Development Limited) under guidance from BeagleBoard.org Foundation.
.. _beaglebone-compatibilityd:
BeagleBone Compatibility
The board is intended to provide functionality well beyond BeagleBone Black or BeagleBone AI, while still providing compatibility with BeagleBone Black's expansion headers as
much as possible. There are several significant differences between the three designs.
.. _beaglebone-comparison-table, BeagleBone Comparisond:
.. list-table:: Table: BeagleBone Compatibility
:header-rows: 1
* - Feature
- AI-64
- AI
- Black
* - SoC
- TDA4VM
- AM5729
- AM3358
* - Arm CPU
- Cortex-A72 (64-bit)
- Cortex-A15 (32-bit)
- Cortex-A8 (32-bit)
* - Arm cores/MHz
- 2x 2GHz
- 2x 1.5GHz
- 1x 1GHz
* - RAM
- 4GB
- 1GB
- 512MB
* - eMMC flash
- 16GB
- 16GB
- 4GB
* - Size
- 4" x 3.1"
- 3.4" x 2.1"
- .4" x 2.1"
* - Display
- miniDP + DSI
- microHDMI
- microHDMI
* - USB host (Type-A)
- 2x 5Gbps
- 1x 480Mbps
- 1x 480Mbps
* - USB dual-role
- Type-C 5Gbps
- Type-C 5Gbps
- mini-AB 480Mbps
* - Ethernet
- 10/100/1000M
- 10/100/1000M
- 10/100M
* - M.2
- E-key
* - WiFi/ Bluetooth
- AzureWave AW&#8209;CM256SM
.. note ::
TODO: add cape compatibility details
.. _beaglebone-ai-64-features-and-specificationd:
BeagleBone AI-64 Features and Specification
This section covers the specifications and features of the board and provides a high level description of the major components and interfaces that make up the board.
.. _ai64-features,BeagleBone AI-64 features tabled:
.. list-table:: Table: BeagleBone AI-64 Features and Specification
:header-rows: 1
- Feature
* - **Processor**
- Texas Instruments TDA4VM
* - **Graphics Engine**
- PowerVR® Series8XE GE8430
* - **SDRAM Memory**
- LPDDR4 3.2GHz (4GB) Kingston Q3222PM1WDGTK-U
* - **Onboard Flash**
- eMMC (16GB) Kingston EMMC16G-TB29-PZ90
* - **PMIC**
- TPS65941213 and TPS65941111 PMICs regulator and one additional LDO.
* - **Debug Support**
- 2x 3 pin 3.3V TTL header
1. WKUP_UART0: Wake-up domain serial port
2. UART0: Main domain serial port
10-pin JTAG TAG-CONNECT footprint
* - **Power Source**
- USB C or DC Jack (5V, >3A)
* - **PCB**
- 4” x 3.1”
* - **Indicators**
- 1-Power, 5-User Controllable LEDs
* - **USB-3.0 Client Port**
- Access to USB0, SuperSpeed, dual-role mode via USB-C (no power output)
* - **USB-3.0 Host Port**
- TUSB8041 4-port SuperSpeed hub on USB1, 2xType A Socket, up-to 2.8A total, depending on power input
* - **Ethernet**
- Gigabit, RJ45, link indicator, speed indicator
* - **SD/MMC Connector**
- microSD , 1.8/3.3V
* - **User Input**
1. Reset Button
2. Boot Button
3. Power Button
* - **Video Out**
- miniDP
* - **Audio**
- via miniDP (stereo)
* - **Weight**
- 192gm (with heatsink)
* - **Power**
- Refer to :ref:`main-board-power` section
.. _board-component-locations:
Board Component Locations
This section describes the key components on the board. It provides information on their location and function. Familiarize yourself with the various components on the board.
.. _board-components:
Board components
:ref:`board-components-figure` below shows the locations of the connectors, LEDs, and switches on the PCB layout of the board.
.. _board-components-figure:
.. figure:: images/ch04/components.png
:width: 400px
:align: center
:alt: BeagleBone AI-64 board components
Fig: BeagleBone AI-64 board components
* **DC Power** is the main DC input that accepts 5V power.
* **Power Button** alerts the processor to initiate the power down sequence and is used to power down the board.
* **GigaBit Ethernet** is the connection to the LAN.
* **Serial Debug ports** WKUP_UART0 for early boot from the management MCU and UART0 is for the main processor.
* **USB Client** is a USB-C connection to a PC that can also power the board.
* **BOOT switch** can be used to force a boot from the microSD card if the power is cycled on the board, removing power and reapplying the power to the board.
* There are five green **LEDs** that can be used by the user.
* **Reset Button** allows the user to reset the processor.
* **microSD** slot is where a microSD card can be installed.
* **miniDP** connector is where the display is connected to.
* **USB Host** can be connected different USB interfaces such as Wi-Fi, Bluetooth, Keyboard, etc.
On bottom side we have,
* **TI TDA4VM** processor.
* **4GB LPDDR4** Dual Data Rate RAM memory.
* **Ethernet PHY** physical interface to the network.
* **eMMC** onboard MMC chip that holds up to 16GB of data.
.. _section-9,Section 9.0 BeagleBone AI-64 Mechanical:
Size: 102.5 x 80 (4" x 3.15")
Max height: #TODO#
PCB Layers: #TODO#
PCB thickness: 2mm (0.08")
RoHS Compliant: Yes
Weight: 192gm
.. figure:: images/ch09/board-dimensions.jpg
:width: 400px
:align: center
:alt: Fig: Board Dimensions
.. figure:: images/ch09/top-silkscreen.png
:width: 400px
:align: center
:alt: Fig: Top silkscreen
Fig: Top silkscreen
.. figure:: images/ch09/bottom-silkscreen.png
:width: 400px
:align: center
:alt: Fig: Bottom silkscreen
.. _pictures:
Pictures
.. figure:: images/ch10/front.jpg
:width: 400px
:align: center
:alt: Fig: BeagleBone AI-64 front
.. figure:: images/ch10/back.jpg
:width: 400px
:align: center
:alt: Fig: BeagleBone AI-64 back
.. figure:: images/ch10/back-heatsink.jpg
:width: 400px
:align: center
:alt: Fig: BeagleBone AI-64 back with heatsink
.. figure:: images/ch10/45-front.jpg
:width: 400px
:align: center
:alt: Fig: BeagleBone AI-64 front at 45° angle
.. figure:: images/ch10/45-back.jpg
:width: 400px
:align: center
:alt: Fig: BeagleBone AI-64 back at 45° angle
.. figure:: images/ch10/45-back-heatsink.jpg
:width: 400px
:align: center
:alt: Fig: BeagleBone AI-64 back with heatsink at 45° angle
.. figure:: images/ch10/feature.jpg
:width: 400px
:align: center
:alt: Fig: BeagleBone AI-64 ports
.. _support-information:
Support Information
All support for this design is through BeagleBoard.org community at: link: `BeagleBoard.org forum <https://forum.beagleboard.org/>`_ .
Hardware Design
You can find all BeagleBone AI-64 hardware files `here <https://git.beagleboard.org/beagleboard/beaglebone-ai-64/-/tree/master/hw>`_ .
Software Updates
You can download and flash the supported image onto your BeagleBone AI-64 from `this <https://debian.beagle.cc/images/bbai64-emmc-flasher-debian-11.2-xfce-arm64-2022-01-14-8gb.img.xz>`_ source.
.. _rma-support:
RMA Support
.. warning::
When connecting to an HDMI monitor, make sure your miniDP adapter is *active*. A *passive* adapter will not work. See :ref:`display-adaptors-figure`.
.. _getting-help:
Getting Help
If you need some up to date troubleshooting techniques, you can post your queries on link: `BeagleBoard.org forum <https://forum.beagleboard.org/>`_
...@@ -29,7 +29,7 @@ Their properties like shown below. ...@@ -29,7 +29,7 @@ Their properties like shown below.
inputs: inputs:
input0: #Camera Input input0: #Camera Input
source: /dev/video2 #Device file entry of the camera source: /dev/video2 #Device file entry of the camera
format: jpeg #Input data format suported by camera format: jpeg #Input data format supported by camera
width: 1280 #Width and Height of the input width: 1280 #Width and Height of the input
height: 720 height: 720
framerate: 30 #Framerate of the source framerate: 30 #Framerate of the source
...@@ -110,7 +110,7 @@ input section of config file. ...@@ -110,7 +110,7 @@ input section of config file.
framerate: 30 framerate: 30
input2: input2:
source: /dev/video2 #IMX219 raw sensor that nees ISP source: /dev/video2 #IMX219 raw sensor that needs ISP
format: rggb #ISP will be added in the pipeline format: rggb #ISP will be added in the pipeline
width: 1920 width: 1920
height: 1080 height: 1080
...@@ -118,7 +118,7 @@ input section of config file. ...@@ -118,7 +118,7 @@ input section of config file.
subdev-id: 2 #needed by ISP to control sensor params via ioctls subdev-id: 2 #needed by ISP to control sensor params via ioctls
input3: input3:
source: /dev/video2 #IMX390 raw sensor that nees ISP source: /dev/video2 #IMX390 raw sensor that needs ISP
width: 1936 width: 1936
height: 1100 height: 1100
format: rggb12 #ISP will be added in the pipeline format: rggb12 #ISP will be added in the pipeline
...@@ -194,7 +194,7 @@ via RTSP server running on a remote PC can be provided as inputs to the demo. ...@@ -194,7 +194,7 @@ via RTSP server running on a remote PC can be provided as inputs to the demo.
Usually video streams from any IP camera will be encrypted and cannot be Usually video streams from any IP camera will be encrypted and cannot be
played back directly without a decryption key. We tested RTSP source by played back directly without a decryption key. We tested RTSP source by
setting up an RTSP server on a Ubuntu 18.04 PC by refering to this writeup, setting up an RTSP server on a Ubuntu 18.04 PC by referring to this writeup,
`Setting up RTSP server on PC `Setting up RTSP server on PC
<https://gist.github.com/Santiago-vdk/80c378a315722a1b813ae5da1661f890>`_ <https://gist.github.com/Santiago-vdk/80c378a315722a1b813ae5da1661f890>`_
...@@ -230,7 +230,7 @@ Below are some of the use case specific properties: ...@@ -230,7 +230,7 @@ Below are some of the use case specific properties:
output output
The content of the model directory and its structure is discussed in detail in The content of the model directory and its structure is discussed in detail in
:ref:`pub_edgeai_import_custom_models` :ref:`ai_64_edgeai_import_custom_models`
Outputs Outputs
...@@ -12,7 +12,7 @@ The **app_edgeai** application at a high level can be split into 3 parts, ...@@ -12,7 +12,7 @@ The **app_edgeai** application at a high level can be split into 3 parts,
Here are the data flows for each reference demo and the corresponding GStreamer Here are the data flows for each reference demo and the corresponding GStreamer
launch strings that **app_edgeai** application generates. User can interact with launch strings that **app_edgeai** application generates. User can interact with
the application via the :ref:`pub_edgeai_configuration` the application via the :ref:`ai_64_edgeai_configuration`
.. _ai_64_edgeai_image_classification_data_flow: .. _ai_64_edgeai_image_classification_data_flow:
