  • beagleboard/image-builder
  • jkridner/image-builder
  • superchamp234/image-builder
  • ayush1325/image-builder
4 results
Commits on Source (3242)
with 991 additions and 241 deletions
# These are supported funding model platforms
github: beagleboad # Replace with up to 4 GitHub Sponsors-enabled usernames e.g., [user1, user2]
patreon: beagleboard # Replace with a single Patreon username
open_collective: # Replace with a single Open Collective username
ko_fi: # Replace with a single Ko-fi username
tidelift: # Replace with a single Tidelift platform-name/package-name e.g., npm/babel
community_bridge: # Replace with a single Community Bridge project-name e.g., cloud-foundry
liberapay: # Replace with a single Liberapay username
issuehunt: # Replace with a single IssueHunt username
otechie: # Replace with a single Otechie username
custom: https://paypal.me/beagleboard # Replace with up to 4 custom sponsorship URLs e.g., ['link1', 'link2']
...@@ -5,3 +5,5 @@ git/ ...@@ -5,3 +5,5 @@ git/
*.host *.host
release release
.project .project
.DS_Store
# Building Bela Images
## **Generate**: Base Debian Images
### Debian Stretch 9.13
git clone https://github.com/RobertCNelson/omap-image-builder
cd ./omap-image-builder
./RootStock-NG.sh -c bela.io-debian-stretch-armhf-v4.14-ti-xenomai
### Debian Bullseye 11.4
./RootStock-NG.sh -c bela.io-debian-bullseye-v4.14-ti-xenomai-armhf
### Archive will be under './deploy/'
### Finalize: Bela specific version:
sudo ./setup_sdcard.sh --img-4gb bela-example --dtb beaglebone --distro-bootloader --enable-cape-universal --enable-uboot-disable-pru --enable-load-bela-overlay
pipeline {
agent { label 'debian-arm64'}
stages {
stage('Build') {
steps {
sh '/bin/bash ./validate.sh'
...@@ -26,64 +26,51 @@ TIME=$(date +%Y-%m-%d) ...@@ -26,64 +26,51 @@ TIME=$(date +%Y-%m-%d)
OIB_DIR="$( cd "$(dirname "$0")" ; pwd -P )" OIB_DIR="$( cd "$(dirname "$0")" ; pwd -P )"
DIR="$PWD" DIR="$PWD"
mkdir -p ${DIR}/ignore
if [ -f ${DIR}/.project ] ; then usage () {
. ${DIR}/.project echo "usage: ./RootStock-NG.sh -c bb.org-debian-stretch-lxqt-v4.14"
fi
generic_git () {
if [ ! -f ${DIR}/git/${git_project_name}/.git/config ] ; then
git clone ${git_clone_address} ${DIR}/git/${git_project_name} --depth=1
fi
update_git () { checkparm () {
if [ -f ${DIR}/git/${git_project_name}/.git/config ] ; then if [ "$(echo $1|grep ^'\-')" ] ; then
cd ${DIR}/git/${git_project_name}/ echo "E: Need an argument"
git pull --rebase || true usage
cd -
fi fi
git_trees () { check_project_config_legacy () {
if [ ! -d ${DIR}/git/ ] ; then
mkdir -p ${DIR}/git/ if [ ! -d ${DIR}/ignore ] ; then
fi fi
tempdir=$(mktemp -d -p ${DIR}/ignore)
git_project_name="linux-firmware" time=$(date +%Y-%m-%d)
git_clone_address="https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git"
generic_git
update_git
run_roostock_ng () { #/config/legacy/${project_config}.conf
if [ ! -f ${DIR}/.project ] ; then unset leading_slash
echo "error: [.project] file not defined" leading_slash=$(echo ${project_config} | grep "/" || unset leading_slash)
exit 1 if [ "${leading_slash}" ] ; then
else project_config=$(echo "${leading_slash##*/}")
echo "Debug: .project"
echo "-----------------------------"
cat ${DIR}/.project
fi fi
if [ ! "${tempdir}" ] ; then #${project_config}.conf
tempdir=$(mktemp -d -p ${DIR}/ignore) project_config=$(echo ${project_config} | awk -F ".conf" '{print $1}')
echo "tempdir=\"${tempdir}\"" >> ${DIR}/.project if [ -f ${DIR}/configs/legacy/${project_config}.conf ] ; then
fi . <(m4 -P ${DIR}/configs/legacy/${project_config}.conf)
export_filename="${deb_distribution}-${release}-${image_type}-${deb_arch}-${time}"
/bin/bash -e "${OIB_DIR}/scripts/install_dependencies.sh" || { exit 1 ; } # for automation
/bin/bash -e "${OIB_DIR}/scripts/debootstrap.sh" || { exit 1 ; } echo "${export_filename}" > ${DIR}/latest_version
/bin/bash -e "${OIB_DIR}/scripts/chroot.sh" || { exit 1 ; }
sudo rm -rf ${tempdir}/ || true
checkparm () { echo "tempdir=\"${tempdir}\"" > ${DIR}/.project
if [ "$(echo $1|grep ^'\-')" ] ; then echo "time=\"${time}\"" >> ${DIR}/.project
echo "E: Need an argument" echo "export_filename=\"${export_filename}\"" >> ${DIR}/.project
usage echo "#" >> ${DIR}/.project
m4 -P ${DIR}/configs/legacy/${project_config}.conf >> ${DIR}/.project
else
echo "Invalid *.conf"
exit
fi fi
...@@ -136,22 +123,24 @@ check_saved_config () { ...@@ -136,22 +123,24 @@ check_saved_config () {
fi fi
git_trees
cd ${DIR}/
unset need_to_compress_rootfs unset need_to_compress_rootfs
# parse commandline options # parse commandline options
while [ ! -z "$1" ] ; do while [ ! -z "$1" ] ; do
case $1 in case $1 in
-h|--help) -h|--help)
usage usage
exit
-c|-C|--config) -c|-C|--config)
checkparm $2 checkparm $2
project_config="$2" project_config="$2"
check_project_config check_project_config
-l|-L|--legacy)
checkparm $2
project_config="$2"
--saved-config) --saved-config)
check_saved_config check_saved_config
...@@ -159,6 +148,94 @@ while [ ! -z "$1" ] ; do ...@@ -159,6 +148,94 @@ while [ ! -z "$1" ] ; do
shift shift
done done
. ${DIR}/.project
fi
generic_git () {
fi
generic_git_mirror () {
git clone -c http.sslVerify=false ${git_clone_address} ${DIR}/git/${git_project_name}
fi
update_git () {
cd -
fi
update_git_mirror () {
git remote set-url origin ${git_clone_address}
cd -
fi
git_trees () {
fi
if [ -f ./.gitea.mirror ] ; then
git_clone_address="https://git.gfnd.rcn-ee.org/kernel.org/linux-firmware.git"
generic_git_mirror
update_git_mirror
else
git_clone_address="https://kernel.googlesource.com/pub/scm/linux/kernel/git/firmware/linux-firmware.git"
generic_git
update_git
fi
#update_git
exit 1
else
cat ${DIR}/.project
fi
fi
echo "Log: stat ${tempdir}"
sudo chown root:root ${tempdir}
sudo chmod 755 ${tempdir}
stat ${tempdir}
echo 'Log: /bin/bash -e "${OIB_DIR}/scripts/install_dependencies.sh"'
echo 'Log: /bin/bash -e "${OIB_DIR}/scripts/debootstrap.sh"'
echo 'Log: /bin/bash -e "${OIB_DIR}/scripts/chroot.sh"'
echo 'Log: RootStock-NG.sh complete'
git_trees
cd ${DIR}/
run_roostock_ng run_roostock_ng
Generate: Base Ubuntu 20.04 Image:
./RootStock-NG.sh -c rcn-ee.net-console-ubuntu-2004-v5.10-ti-armhf
Archive will be under "./deploy/"
Finalize: BeagleBone Black specific version:
sudo ./setup_sdcard.sh --img-4gb bone-example --dtb beaglebone --distro-bootloader --enable-cape-universal --enable-uboot-disable-pru --enable-bypass-bootup-scripts
Finalize: BeagleBoard-x15 specific version:
sudo ./setup_sdcard.sh --img-4gb am57xx-example --dtb am57xx-beagle-x15 --distro-bootloader --enable-uboot-cape-overlays --enable-bypass-bootup-scripts
Generate: Base Ubuntu 22.04 Image:
./RootStock-NG.sh -c rcn-ee.net-console-ubuntu-2204-v5.10-ti-armhf
#!/bin/bash -e
DIR="$PWD"
./RootStock-NG.sh -c bb.org-debian-jessie-lxqt-2gb-v4.4
./RootStock-NG.sh -c bb.org-debian-jessie-lxqt-4gb-v4.4
./RootStock-NG.sh -c bb.org-debian-jessie-console-v4.4
debian_jessie_lxqt_2gb="debian-8.10-lxqt-2gb-armhf-${time}"
debian_jessie_lxqt_4gb="debian-8.10-lxqt-4gb-armhf-${time}"
debian_jessie_console="debian-8.10-console-armhf-${time}"
archive="xz -z -8 -v"
beaglebone="--dtb beaglebone --bbb-old-bootloader-in-emmc --hostname beaglebone"
bb_blank_flasher="--dtb bbb-blank-eeprom --bbb-old-bootloader-in-emmc \
beaglebone_console="--dtb beaglebone --bbb-old-bootloader-in-emmc \
bb_blank_flasher_console="--dtb bbb-blank-eeprom --bbb-old-bootloader-in-emmc \
omap3_beagle_xm="--dtb omap3-beagle-xm --hostname BeagleBoard"
omap5_uevm="--dtb omap5-uevm --hostname omap5-uevm"
am57xx_beagle_x15="--dtb am57xx-beagle-x15 --hostname BeagleBoard-X15"
cat > ${DIR}/deploy/gift_wrap_final_images.sh <<-__EOF__
#!/bin/bash
archive_base_rootfs () {
if [ -d ./\${base_rootfs} ] ; then
rm -rf \${base_rootfs} || true
fi
if [ -f \${base_rootfs}.tar ] ; then
${archive} \${base_rootfs}.tar && sha256sum \${base_rootfs}.tar.xz > \${base_rootfs}.tar.xz.sha256sum &
fi
extract_base_rootfs () {
fi
if [ -f \${base_rootfs}.tar.xz ] ; then
tar xf \${base_rootfs}.tar.xz
else
fi
archive_img () {
#prevent xz warning for 'Cannot set the file group: Operation not permitted'
sudo chown \${UID}:\${GROUPS} \${wfile}.img
if [ -f \${wfile}.img ] ; then
if [ ! -f \${wfile}.bmap ] ; then
if [ -f /usr/bin/bmaptool ] ; then
bmaptool create -o \${wfile}.bmap \${wfile}.img
fi
fi
${archive} \${wfile}.img && sha256sum \${wfile}.img.xz > \${wfile}.img.xz.sha256sum &
fi
generate_img () {
cd \${base_rootfs}/
sudo ./setup_sdcard.sh \${options}
mv *.img ../
mv *.job.txt ../
cd ..
###lxqt-4gb image
base_rootfs="${debian_jessie_lxqt_4gb}" ; blend="lxqt-4gb" ; extract_base_rootfs
options="--img-4gb BBB-eMMC-flasher-\${base_rootfs} ${beaglebone} --emmc-flasher" ; generate_img
options="--img-4gb bone-\${base_rootfs} ${beaglebone}" ; generate_img
options="--img-4gb bbx15-eMMC-flasher-\${base_rootfs} ${am57xx_beagle_x15} --emmc-flasher" ; generate_img
options="--img-4gb bbx15-\${base_rootfs} ${am57xx_beagle_x15}" ; generate_img
###lxqt-2gb image
base_rootfs="${debian_jessie_lxqt_2gb}" ; blend="lxqt-2gb" ; extract_base_rootfs
options="--img-2gb BBB-eMMC-flasher-\${base_rootfs} ${beaglebone} --bbb-flasher" ; generate_img
###console images: (also single partition)
base_rootfs="${debian_jessie_console}" ; blend="console" ; extract_base_rootfs
options="--img-2gb BBB-eMMC-flasher-\${base_rootfs} ${beaglebone_console} --emmc-flasher" ; generate_img
options="--img-2gb bone-\${base_rootfs} ${beaglebone_console}" ; generate_img
options="--img-2gb bbx15-eMMC-flasher-\${base_rootfs} ${am57xx_beagle_x15} --emmc-flasher" ; generate_img
options="--img-2gb bbx15-\${base_rootfs} ${am57xx_beagle_x15}" ; generate_img
###archive *.tar
base_rootfs="${debian_jessie_lxqt_4gb}" ; blend="lxqt-4gb" ; archive_base_rootfs
base_rootfs="${debian_jessie_lxqt_2gb}" ; blend="lxqt-2gb" ; archive_base_rootfs
base_rootfs="${debian_jessie_console}" ; blend="console" ; archive_base_rootfs
blend="lxqt-4gb"
wfile="BBB-eMMC-flasher-${debian_jessie_lxqt_4gb}-4gb" ; archive_img
wfile="bone-${debian_jessie_lxqt_4gb}-4gb" ; archive_img
wfile="bbx15-eMMC-flasher-${debian_jessie_lxqt_4gb}-4gb" ; archive_img
wfile="bbx15-${debian_jessie_lxqt_4gb}-4gb" ; archive_img
blend="lxqt-2gb"
wfile="BBB-eMMC-flasher-${debian_jessie_lxqt_2gb}-2gb" ; archive_img
blend="console"
wfile="BBB-eMMC-flasher-${debian_jessie_console}-2gb" ; archive_img
wfile="bone-${debian_jessie_console}-2gb" ; archive_img
wfile="bbx15-eMMC-flasher-${debian_jessie_console}-2gb" ; archive_img
wfile="bbx15-${debian_jessie_console}-2gb" ; archive_img
__EOF__
chmod +x ${DIR}/deploy/gift_wrap_final_images.sh
bb.org-jessie-snapshot-auto
Schedule:
H 7 1 * *
shell:
#!/bin/bash
touch jenkins.build
./publish/rcn-ee_bb.org-stable.sh
machinekit-debian-jessie
bb.org-debian-jessie-iot-v4.4
bb.org-debian-jessie-lxqt-4gb-xm
bb.org-debian-jessie-oemflasher
seeed-debian-jessie-lxqt-4gb-v4.4
seeed-debian-jessie-iot-v4.4
shell:
#!/bin/bash
image_prefix=bb.org
if [ ! -f /mnt/farm/images/original.txt ] ; then
sudo mount -a || true
fi
if [ -d ./deploy ] ; then
rm -rf ./deploy || true
fi
#./RootStock-NG.sh -c machinekit-debian-jessie
#./RootStock-NG.sh -c bb.org-debian-jessie-console-v4.4
#./RootStock-NG.sh -c bb.org-debian-jessie-iot-v4.4
#./RootStock-NG.sh -c bb.org-debian-jessie-lxqt-2gb-v4.4
#./RootStock-NG.sh -c bb.org-debian-jessie-lxqt-4gb-v4.4
#./RootStock-NG.sh -c bb.org-debian-jessie-lxqt-4gb-xm
#./RootStock-NG.sh -c bb.org-debian-jessie-oemflasher
#./RootStock-NG.sh -c seeed-debian-jessie-lxqt-4gb-v4.4
#./RootStock-NG.sh -c seeed-debian-jessie-iot-v4.4
if [ -f ./deploy/*.tar ] ; then
ls -lha ./deploy/
echo "Copying: *.tar to server: images/${image_prefix}-${time}/"
cp -v ./deploy/*.tar /mnt/farm/images/${image_prefix}-${time}/ || true
else
exit 1
fi
...@@ -12,15 +12,16 @@ touch jenkins.build ...@@ -12,15 +12,16 @@ touch jenkins.build
./publish/rcn-ee_bb.org-stable.sh ./publish/rcn-ee_bb.org-stable.sh
bb.org-debian-stretch-console-v4.9 machinekit-debian-stretch
bb.org-debian-stretch-iot-v4.4
bb.org-debian-stretch-iot-v4.9 bb.org-debian-stretch-console-v4.14
bb.org-debian-stretch-lxqt-2gb-v4.9 bb.org-debian-stretch-iot-v4.14
bb.org-debian-stretch-lxqt-v4.9 bb.org-debian-stretch-lxqt-v4.14
bb.org-debian-stretch-lxqt-xm bb.org-debian-stretch-lxqt-xm
bb.org-debian-stretch-oemflasher-v4.4
bb.org-debian-buster-iot-v4.9 bb.org-debian-buster-iot-v4.14
bb.org-ubuntu-bionic-ros-iot-v4.14
shell: shell:
...@@ -29,6 +30,8 @@ shell: ...@@ -29,6 +30,8 @@ shell:
image_prefix=bb.org image_prefix=bb.org
time=$(date +%Y-%m-%d) time=$(date +%Y-%m-%d)
export apt_proxy=apt-proxy:3142/
if [ ! -f /mnt/farm/images/original.txt ] ; then if [ ! -f /mnt/farm/images/original.txt ] ; then
sudo mount -a || true sudo mount -a || true
fi fi
...@@ -37,15 +40,16 @@ if [ -d ./deploy ] ; then ...@@ -37,15 +40,16 @@ if [ -d ./deploy ] ; then
rm -rf ./deploy || true rm -rf ./deploy || true
fi fi
#./RootStock-NG.sh -c bb.org-debian-stretch-console-v4.9 #./RootStock-NG.sh -c machinekit-debian-stretch
#./RootStock-NG.sh -c bb.org-debian-stretch-iot-v4.4
#./RootStock-NG.sh -c bb.org-debian-stretch-iot-v4.9 #./RootStock-NG.sh -c bb.org-debian-stretch-console-v4.14
#./RootStock-NG.sh -c bb.org-debian-stretch-lxqt-2gb-v4.9 #./RootStock-NG.sh -c bb.org-debian-stretch-iot-v4.14
#./RootStock-NG.sh -c bb.org-debian-stretch-lxqt-v4.9 #./RootStock-NG.sh -c bb.org-debian-stretch-lxqt-v4.14
#./RootStock-NG.sh -c bb.org-debian-stretch-lxqt-xm #./RootStock-NG.sh -c bb.org-debian-stretch-lxqt-xm
#./RootStock-NG.sh -c bb.org-debian-stretch-oemflasher-v4.4
#./RootStock-NG.sh -c bb.org-debian-buster-iot-v4.9 #./RootStock-NG.sh -c bb.org-debian-buster-iot-v4.14
#./RootStock-NG.sh -c bb.org-ubuntu-bionic-ros-iot-v4.14
if [ -f ./deploy/*.tar ] ; then if [ -f ./deploy/*.tar ] ; then
ls -lha ./deploy/ ls -lha ./deploy/
#!/bin/bash
export apt_proxy=192.168.1.10:3142/
config=bb.org-debian-bullseye-home-assistant-v5.10-ti-arm64-k3-am62
filesize=8gb
rootfs="debian-arm64-11-bullseye-home-assistant-v5.10-ti"
compress_snapshot_image () {
json_file="${device}-${export_filename}-${filesize}.img.xz.json"
sudo -uvoodoo mkdir -p /mnt/mirror/rcn-ee.us/rootfs/${rootfs}/${time}/
sync
extract_size=$(du -b ./${device}-${export_filename}-${filesize}.img | awk '{print $1}')
echo "\"extract_size\": ${extract_size}," >> ${json_file}
extract_sha256=$(sha256sum ./${device}-${export_filename}-${filesize}.img | awk '{print $1}')
echo "\"extract_sha256\": \"${extract_sha256}\"," >> ${json_file}
echo "Creating... ${device}-${export_filename}-${filesize}.bmap"
bmaptool -d create -o ./${device}-${export_filename}-${filesize}.bmap ./${device}-${export_filename}-${filesize}.img
echo "Compressing... ${device}-${export_filename}-${filesize}.img"
xz -T0 -z ${device}-${export_filename}-${filesize}.img
sync
image_download_size=$(du -b ./${device}-${export_filename}-${filesize}.img.xz | awk '{print $1}')
echo "\"image_download_size\": ${image_download_size}," >> ${json_file}
image_download_sha256=$(sha256sum ./${device}-${export_filename}-${filesize}.img.xz | awk '{print $1}')
echo "\"image_download_sha256\": \"${image_download_sha256}\"," >> ${json_file}
echo "\"release_date\": \"${time}\"," >> ${json_file}
echo "\"init_format\": \"sysconf\"," >> ${json_file}
sync
sha256sum ${device}-${export_filename}-${filesize}.img.xz > ${device}-${export_filename}-${filesize}.img.xz.sha256sum
sudo -uvoodoo cp -v ./${device}-${export_filename}-${filesize}.bmap /mnt/mirror/rcn-ee.us/rootfs/${rootfs}/${time}/
sudo -uvoodoo cp -v ./${device}-${export_filename}-${filesize}.img.xz /mnt/mirror/rcn-ee.us/rootfs/${rootfs}/${time}/
sudo -uvoodoo cp -v ./${device}-${export_filename}-${filesize}.img.xz.sha256sum /mnt/mirror/rcn-ee.us/rootfs/${rootfs}/${time}/
sudo -uvoodoo cp -v ./${device}-${export_filename}-${filesize}.img.xz.json /mnt/mirror/rcn-ee.us/rootfs/${rootfs}/${time}/
sudo rm -rf ./deploy || true
fi
touch .notar
touch .gitea.mirror
echo "./RootStock-NG.sh -c ${config}"
source .project
if [ -d ./deploy/${export_filename}/ ] ; then
cd ./deploy/${export_filename}/
echo "sudo ./setup_sdcard.sh --img-${filesize} beagleplay-${export_filename} --dtb beagleplay"
mv ./*.img ../
cd ../
device="beagleplay" ; compress_snapshot_image
#echo "Compressing...${export_filename}.tar"
#xz -T0 -z ${export_filename}.tar
#sha256sum ${export_filename}.tar.xz > ${export_filename}.tar.xz.sha256sum
#sudo -uvoodoo cp -v ./${export_filename}.tar.xz /mnt/mirror/rcn-ee.us/rootfs/${rootfs}/${time}/
#sudo -uvoodoo cp -v ./${export_filename}.tar.xz.sha256sum /mnt/mirror/rcn-ee.us/rootfs/${rootfs}/${time}/
rm -rf ${tempdir} || true
else
echo "failure"
exit 2
fi
#!/bin/bash
config=bb.org-debian-bullseye-home-assistant-v5.10-ti-arm64-k3-j721e
filesize=8gb
sync
sync
sync
fi
touch .notar
touch .gitea.mirror
source .project
echo "sudo ./setup_sdcard.sh --img-${filesize} bbai64-${export_filename} --dtb bbai64"
mv ./*.img ../
cd ../
device="bbai64" ; compress_snapshot_image
else
echo "failure"
exit 2
fi
#!/bin/bash
config=bb.org-debian-bullseye-minimal-v5.10-ti-arm64-k3-am62
filesize=6gb
rootfs="debian-arm64-11-bullseye-minimal-v5.10-ti"
sync
sync
sync
fi
touch .notar
touch .gitea.mirror
source .project
echo "sudo ./setup_sdcard.sh --img-${filesize} beagleplay-${export_filename} --dtb beagleplay-swap"
mv ./*.img ../
cd ../
else
echo "failure"
exit 2
fi
#!/bin/bash
config=bb.org-debian-bullseye-minimal-v5.10-ti-arm64-k3-j721e
filesize=4gb
sync
sync
sync
fi
touch .notar
touch .gitea.mirror
source .project
mv ./*.img ../
cd ../
else
echo "failure"
exit 2
fi
#!/bin/bash
config=bb.org-debian-bullseye-xfce-edgeai-v5.10-ti-arm64-k3-j721e
filesize=10gb
rootfs="debian-arm64-11-bullseye-xfce-edgeai-v5.10-ti"
sync
sync
sync
fi
touch .notar
touch .gitea.mirror
source .project
echo "sudo ./setup_sdcard.sh --img-${filesize} bbai64-emmc-flasher-${export_filename} --dtb bbai64 --enable-extlinux-flasher"
mv ./*.img ../
cd ../
device="bbai64-emmc-flasher" ; compress_snapshot_image
else
echo "failure"
exit 2
fi
#!/bin/bash
config=bb.org-debian-bullseye-xfce-v5.10-ti-arm64-k3-am62
filesize=12gb
rootfs="debian-arm64-11-bullseye-xfce-v5.10-ti"
sync
sync
sync
fi
touch .notar
touch .gitea.mirror
source .project
mv ./*.img ../
cd ../
else
echo "failure"
exit 2
fi
#!/bin/bash
config=bb.org-debian-bullseye-xfce-v5.10-ti-arm64-k3-j721e
filesize=12gb
sync
sync
sync
fi
touch .notar
touch .gitea.mirror
source .project
mv ./*.img ../
cd ../
else
echo "failure"
exit 2
fi
#!/bin/bash
config=bb.org-debian-bookworm-cinnamon-v6.1-ti-arm64-k3-j721e
filesize=12gb
rootfs="debian-arm64-12-bookworm-cinnamon-v6.1-ti"
sync
sync
sync
fi
touch .notar
touch .gitea.mirror
source .project
echo "sudo ./setup_sdcard.sh --img-${filesize} bbai64-${export_filename} --dtb bbai64-swap"
mv ./*.img ../
echo "sudo ./setup_sdcard.sh --img-${filesize} bbai64-emmc-flasher-${export_filename} --dtb bbai64-swap --enable-extlinux-flasher"
mv ./*.img ../
cd ../
else
echo "failure"
exit 2
fi
#!/bin/bash
config=bb.org-debian-bookworm-cinnamon-v6.1-ti-arm64-k3-j722s
filesize=12gb
sync
sync
sync
fi
touch .notar
touch .gitea.mirror
source .project
echo "sudo ./setup_sdcard.sh --img-${filesize} beagley-ai-${export_filename} --dtb beagley-ai-swap"
mv ./*.img ../
cd ../
device="beagley-ai" ; compress_snapshot_image
else
echo "failure"
exit 2
fi
#!/bin/bash
config=bb.org-debian-bookworm-cinnamon-v6.6-ti-arm64-k3-am62
filesize=12gb
rootfs="debian-arm64-12-bookworm-cinnamon-v6.6-ti"
sync
sync
sync
fi
touch .notar
touch .gitea.mirror
source .project
mv ./*.img ../
echo "sudo ./setup_sdcard.sh --img-${filesize} beagleplay-emmc-flasher-${export_filename} --dtb beagleplay-swap --enable-extlinux-flasher"
mv ./*.img ../
cd ../
device="beagleplay-emmc-flasher" ; compress_snapshot_image
else
echo "failure"
exit 2
fi
